Adjusting Intonation?
Posted 2009-01-06 3:12 AM (#434916)
Subject: Adjusting Intonation?
Okay... Correct me if I am wrong.
With correct intonation, I should be able to get a correctly tuned note on the open sting and 12th fret.
To get this, I can adjust the saddle of the guitar.
On a Viper, and/or my other electric guitars.
I have done a OFC search, and a few Google searches, and I cannot find instructions/directions on how to do this correctly.
Can anyone give me the quick Dummies' lesson on how to do this correctly?
Or direct me to a site that will do so?
[I Thank You... And my neighbors Thank you also! :p ]
Posted 2009-01-06 5:11 AM (#434917 - in reply to #434916)
Subject: Re: Adjusting Intonation?
If the harmonic is sharp to the fretted note then adjust the saddle towards the tail piece. Vice-versa if the harmonic is flat.
AussieJames
Posted 2009-01-06 7:31 AM (#434918 - in reply to #434916)
June 2007
What Schroeder said!!
If it's sharp the distance between the saddle and the 12th is too short so you have to lengthen it by adjusting the saddle towards the tailpiece. And vice versa.
Use a tuner not your ear!!
The other thing to remember is be conscious of how hard you fret the string because that will change the pitch.
You need to adjust the intonation using your playing fret tension.
AJ
Posted 2009-01-06 7:58 AM (#434919 - in reply to #434916)
and...
make sure the action is adjusted within tolerance. If it's too high you will also get intonation problems...
Posted 2009-01-06 10:28 AM (#434920 - in reply to #434916)
Now if we could only adjust Jeff within tolerance... :p
Posted 2009-01-06 10:36 AM (#434921 - in reply to #434916)
you'd have to shave my nuts...
Posted 2009-01-06 10:40 AM (#434922 - in reply to #434916)
again??
Posted 2009-01-06 1:14 PM (#434923 - in reply to #434916)
Lemme find my grinder...
