Picture of some DIY guitar repair tools
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | Craftsman level used to level frets $10.00. use contact glue to adhere 1" wide strip of sandpaper to level. 1"x1/2"x18" piece of Oak $2.99(purchased at Lowes)notched out to fit over the frets, this will allow you to adjust the truss rod until the neck is perfectly straight before leveling frets. Fret leveling file, made from a cut down Nicholson mill file, and glued to a small piece of Oak, Used to rough in very high frets. Set of nut slotting files from Stewmac .008, .010, .015, .020, .025 thicknesses. $39.90 Small end cutters filled flat on the bottom, used to pull frets from fretboard. $5.00 for a set of small cutters from local dollar store. Fret press, made from large throat vise grips $21.99 (Used in welding) with a slightly modified Fret caul from Stewmac $51.95 includes inserts, and a piece of neck support caul from Stewmac $10.40. ![]() | ||
| Joey Joe |
Joined: March 2004 Posts: 86 Location: Detroit area | I expected to see a 12 pack of Budweiser. | ||
| FlicKreno aka Solid Top |
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Interesting , particularly that Fret -Clamp. Vic | ||
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | Originally posted by HumblePie aka Solid Top: If you like the fret clamp, you'll love the knife I made using an old Nicholson file... Interesting , particularly that Fret -Clamp. Vic Talk about holding an edge! If anyone is interested I can post step by step instructions on making your own fret press. ![]() | ||
| fran4001 |
Joined: January 2005 Posts: 206 Location: N.E. Pa | Was wondering meself what the fret files look like. I'm trying to get up the nerve to lower the slots on my CC247 since I think it's cut a bit too shallow, and therefore a bit hard to fret. I suppose I'll need to pick that set up. StewMac IS great to deal with though. I've used them lots over the years. | ||
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | Those are fret saws, they are for roughing in the nut slots, however, if you use them carefully you can get the same results......the nut slot files are quite expensive. | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Originally posted by Elliot Meldoy: I have used a small hammer to ( Gently ) tap a fret back into place , but , I would appreciate seeing how to make that fret -press . :) Originally posted by HumblePie aka Solid Top: If you like the fret clamp, you'll love the knife I made using an old Nicholson file... Interesting , particularly that Fret -Clamp. Vic Talk about holding an edge! If anyone is interested I can post step by step instructions on making your own fret press. Vic | ||
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | First you will have to order the fret caul with inserts from stewmac. And purchase a pair of large throat vise grips from any hardware store. remove the pin on the fret caul that holds the shaft to the base, and remove one of the swivels on the vise grips. Now assemble the caul base to the vise grip jaw that you removed the swivel from. you will need a nut and bolt to secure the base to the jaw, you will also need about four small washers to center the caul base and take up any play between the jaw and the caul. I will send you a piece of the neck support caul so don't worry about buying one. Secure the neck caul support to the other swivel on the vise grip using liberal amounts of epoxy. I use two part fast setting epoxy. anyway, after all is said an done you will have an inexpensive fully functioning fret press, and if you keep the shaft and pin from the fret caul, you can re-assemble it down the road and use it with a drill press as well. The drill press works great for pressing frets down over guitar bodies where the fret press can't reach. | ||
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | Oh uh crap, I just realized you are in Copenhagen... That makes sending the piece of neck support caul a little difficult! | ||
| Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Really fine creations there Eliot... | ||
Joined: April 2006 Posts: 2491 Location: Copenhagen Denmark | Originally posted by Elliot Meldoy: Elliot , Oh uh crap, I just realized you are in Copenhagen... That makes sending the piece of neck support caul a little difficult! That`s Okay , I`m an E/M engineer , making such a device is small potatoes , I just needed the Idea / Info , to get onto the right path , Thanks for your Kind offer , I Appreciate it :) Vic | ||
| knuckles |
Joined: February 2008 Posts: 129 Location: Berkeley, CA | Hmmm. Maybe you're an associate of Doctor Oakroot? I'll lay odds he has similar tools. knuckles | ||
| LBJ |
Joined: March 2007 Posts: 665 Location: Tychy, Poland | Originally posted by HumblePie aka Solid Top: Hey, i'm a IT Specialist / programmer, i will write software that will automatically adapt pressing power to fretboard material and fret size. and i can do a database interface that will store once prepared settings... not to mention, that if we would somewhat get some kind of robot arm, i could write a program that would control arm and make it press frets automatically in mathematically counted spacing, different for each guitar scale... Originally posted by Elliot Meldoy: Elliot , Oh uh crap, I just realized you are in Copenhagen... That makes sending the piece of neck support caul a little difficult! That`s Okay , I`m an E/M engineer , making such a device is small potatoes , I just needed the Idea / Info , to get onto the right path , Thanks for your Kind offer , I Appreciate it :) Vic uh, i think after nearly 4 months of double shifts i need to get some rest. | ||
| Elliot Meldoy |
| Joined: April 2007 Posts: 225 Location: Stow, Ohio | Get some sleep LBJ :) | ||
