AA14 - Applause (Aluminum Neck) Question..
Yak
Posted 2009-01-29 8:26 PM (#430753)
Subject: AA14 - Applause (Aluminum Neck) Question..
I have an old Applause AA14, you know, the one with the aluminum neck and fretboard!
The frets on it are completely square edge with a flat top. I assume that it came from the factory this way. The problem is that it's down right dangerous to do any slides on it, as the frets basically shave off your fingertips. So the question is.. Would it be a bad/good idea to take a fine file and round off the fret edges?
Posted 2009-01-29 8:35 PM (#430754 - in reply to #430753)
Subject: Re: AA14 - Applause (Aluminum Neck) Question..
I call those 'speed bumps'. My Academy is similar but without the scalpel effect.
One thing they taught me was that I was applying too much fretboard pressure. On the other hand, if your finger tip callouses need trimming, viola!!! ;)
To be honest, an Applause, I'd smooth the edges. My Academy? Noper!
scott lamperd
Posted 2009-01-29 8:48 PM (#430755 - in reply to #430753)
I have one of those applause guitars, actually one of my favorite Ovations. Stewart McDonald Co
sells fret files that will reshape the tops of the frets. Carefully done, you will end up with a very smooth playing guitar. Any questions, e-mail me; jslamperd@hotmail.com
Scott Lamperd B C (before computers)
Posted 2009-01-29 9:46 PM (#430756 - in reply to #430753)
Depends how old it is. The early ones were just leveled flat. Then later they were nickle plated for longer life. Go ahead and round it off but take as little off as possible, you can't replace it!
numbfingers
Posted 2009-01-29 10:36 PM (#430757 - in reply to #430753)
Beal, were the Academy frets plated or hardened in any way?
Unlike Iffy, I'd like to crown my Academy's frets. Those square edges are sharp! I thought that someone had leveled the frets but not finished the job. I guess that others are this way too.
-Steve W.
Posted 2009-01-29 11:20 PM (#430758 - in reply to #430753)
So would I. But not at the risk of doing unrepairable/non-replaceable damage!
Awaiting Beal's response...
BTW numbdigits, which model do you have? Mine is a -14. Would love to find a -17!
Posted 2009-01-30 8:37 AM (#430759 - in reply to #430753)
Probably, Look closely at them, the nickle is shiney and the aluminum is dull. Want to pick at it and see? go to the 15th-20th fret or so and try rounding it.
ksdaddy
Posted 2009-02-24 11:01 AM (#430760 - in reply to #430753)
April 2003
I crowned the frets on my AA14. They were dangerous. Quite delightful now and well worth the time.
