hi have some more question for you,my Elite Special S868 serial# 543047 arrive yesterday in decent shape but not perfect the string were dead and all the tuner were loose also action was a little high.this morning I clean my new arrival put new string(D'addario EJ16 light)lower'd the action(remove the white shim)no string buzzing the problem is that the .012&.016
seem's to have low volume true my amp all the other string are loud but not the 1-2string
it as the OP24+ pre-amp wath could be the problem
also can the satin finish be polish.
again thank you
Daniel ;) |
Location: Cincinnati | I can't answer your sound problems, but I've used Martin Guitar Polish and Dunlop 65 on my Martin DM which has a satin finish and haven't had any problems. |
Location: Scotland | The string balance problem is most likely down to a faulty pickup. Elite Special probably has a thinllne. Contact customer service and they should be able to help with a replacement pickup |
Hi sent an e-mail to Ovation and im waiting to get an answer
Daniel |
Location: Boise, Idaho | Did you check to see if it worked OK before you removed a shim? I had that problem after I removed a shim on my daughter's thinline, but fixed it by moving things around a little. The problem had something to do with the "white plastic thingy". So a search for that term on this board and you might find a solution. |
the guitar never ad a loud noise on the .012/.016 string so GC will buy from Ovation the pick-up and i will have it put in buy luthier and adjust thing at the same time
Daniel :D
p.s. how can i find an old thread EX.(white plastic thingy) |
Location: Boise, Idaho | Click on the search function on the top of this page and play around with it until you figure out how to use it. You can find many answers to your questions by searching the old posts. |
