Will Viper III fit Les Paul case?
nibblegribitz
Posted 2009-06-16 5:00 PM (#411615)
Subject: Will Viper III fit Les Paul case?
January 2009
Will a Viper III fit Les Paul case?
Posted 2009-06-16 5:11 PM (#411616 - in reply to #411615)
Subject: Re: Will Viper III fit Les Paul case?
I'll verify this tonight, but I doubt it. The Ovation solids are slightly longer.
Posted 2009-06-16 5:12 PM (#411617 - in reply to #411615)
I'd guess no as well, longer scale.
BruDeV
Posted 2009-06-16 10:37 PM (#411618 - in reply to #411615)
The body is different too.
AussieJames
Posted 2009-06-17 12:42 AM (#411619 - in reply to #411615)
June 2007
I didn't think it would but it will, just.
But you need to put some padding under the body to lower the headstock.
AJ
Posted 2009-06-17 9:28 AM (#411620 - in reply to #411615)
Note that the tip of the headstock comes in contact with the inside of the case beyond just the padding. This suggests that the Viper's longer scale makes it slightly oversized for the LP case. It probably could be forced into the case, but I wouldn't do it.
Posted 2009-06-17 12:40 PM (#411621 - in reply to #411615)
just chop off the ears and it will be a perfect fit!
AussieJames
Posted 2009-06-17 7:06 PM (#411622 - in reply to #411615)
June 2007
It's a neat fit but would do the job.
It fits the body quite well.
Because the LP is thicker the case is deeper.
Put about an inch or so of padding under the rear of the body and the headstock sits down in the case just fine, albeit neat.
Lowering the neck support would also help.
I have a spare LP case and a Viper in a gig bag so that's what I am going to do.
Bitz, genuine Viper cases are not that hard to get over there.
Check with Al
AJ
