xlr connecton
Phillym
Posted 2009-06-24 8:10 PM (#410228)
Subject: xlr connecton
June 2009
Does the XLR cable have a 1/4 inch connection on one end and the xlr on the other. If not does the amp have to have an xlr imput on it in order to use this feature?
Posted 2009-06-24 8:12 PM (#410229 - in reply to #410228)
Subject: Re: xlr connecton
No, yes.
bvince
Posted 2009-06-24 8:16 PM (#410230 - in reply to #410228)
September 2005
If you are speaking of the XLR output from your Ovation guitar, you have to use a special XLR cable. A regular XLR cable will not work. I had the same question when I purchased my first Ovation with that feature. What I discovered was that I would probably never use it for regular play, so the cost of the cable wasn't worth it to me. I guess if your were planning on doing some serious recording it may be worth the investment, but the standard 1/4 inch cable works just fine for everything i need to do.
Posted 2009-06-24 9:26 PM (#410231 - in reply to #410228)
It's not 'special', Vince. It just needs to have pin 1 tied to the shell to use phantom. Probably better than 1/2 the XLR cables on the market are wired this way, or it's no big thing to do it yourself, if you can handle a soldering iron.
arlene
Posted 2009-06-24 9:34 PM (#410232 - in reply to #410228)
May 2009
here is what is good about the XLR ouput on the guitar for me. I use an acoutasonic amp that has 2 channels one with 1/4 inch input and the 2nd channel has XLR for Mic. I use 2 guitars when i play out and with this set up, I plug one into the 1/4 inch, and my other guitar with XLR out connects up to the Mic Channel. works great and dont have to keep changing volume and EQ every time i change guitars
TAFKAR
Posted 2009-06-24 9:40 PM (#410233 - in reply to #410228)
For me, the XLR is useful because the volume controls on the PA are locked away so we monkeys can't destroy the settings. The signal out from the XLR packs a much greater punch than from the 1/4". I set it at the first notch for picking and less for strumming. On 1/4" I have to dial my guitar up all the way just to hear it when I'm strumming.
PEZ
Posted 2009-06-25 2:00 AM (#410234 - in reply to #410228)
July 2003
I always use the XLR when ever I can.
(open mics noemally 1/4 inch)
Stronger signal better sound.
