Cracking noise when tightening/loosening strings!
dweezil
Posted 2009-07-01 7:18 AM (#409048)
Subject: Cracking noise when tightening/loosening strings!
Hi,
when I change the strings on my 06C I there is a smallish crack noise when I loosen or tension the strings. It sounds it coming from the neck/body joint. All looks OK on the top and from inside but should I worry/do something about it.
It's done it since I've had it and doesn't seem to be getting worse (as far as I can tell).
G8r
Posted 2009-07-01 7:55 AM (#409049 - in reply to #409048)
Subject: Re: Cracking noise when tightening/loosening strings!
You're sure it's not coming from the nut? If so, a little graphite (pencil lead) in the nut slots will let the strings glide w/o catching. If the sound really is from the neck/body joint I'd worry.
dweezil
Posted 2009-07-01 7:59 AM (#409050 - in reply to #409048)
I'm pretty sure it's not from the nut.
AussieJames
Posted 2009-07-01 9:11 AM (#409051 - in reply to #409048)
June 2007
It's either your knuckles or the nut
Posted 2009-07-01 10:10 AM (#409052 - in reply to #409048)
I'm with Serge and Jim.
If the 'crack/pop' is consistent, place one end of a wooden dowel against you ear and the other end on different parts on the guitar and duplicate the action. You should be able to locate the 'offender'.
Good luck...
Posted 2009-07-01 10:19 AM (#409053 - in reply to #409048)
Does it happen when tuning?
Does it happen to particular strings?
Did you try the graphite?
dweezil
Posted 2009-07-01 10:19 AM (#409054 - in reply to #409048)
I'm pretty sure it's the neck/body join
Posted 2009-07-01 10:21 AM (#409055 - in reply to #409048)
I have been alarmed and then let it go - the LX necks are very light and I have heard sounds from either the dual truss rods or the bolt on joint.
Not a problem but noticeable.
