Tru-Balance vs Hi Output
PEZ
Posted 2009-07-02 2:55 PM (#408870)
Subject: Tru-Balance vs Hi Output
July 2003
Opinions or thoughts on this??
Which is better??
Anyone know if there are examples of the Tru-Balance sound on you tube??
Posted 2009-07-02 3:44 PM (#408871 - in reply to #408870)
Subject: Re: Tru-Balance vs Hi Output
I've had both, but I couldn't tell you what the difference was tonally.
Youtube audio is probably not the best way to judge. Maybe someone (Mike?) could post a couple better quality examples.
FlicKreno aka Solid Top
Posted 2009-07-02 5:05 PM (#408872 - in reply to #408870)
PEZ ,
Tru-Balance as I understand is = Balanced -Configuration ,which means that there should be a 3 pin connector or XLR ..
1 pin is Hot ..
another Cold ..
and the Last is Common ( Earth )
Hi-Output has a Jack..
with a Jack there is a ..
Hot connection ( Tip of Jack )..
Cold is Sleeve.
With Tru-Balance Ya will achieve a Cleaner ( BETTER ) sound , A Must at high levels to Avoid Hum and Hiss and to minimize Distortion.
In order to Utilize that Tru-Balance , Ya MUST use an Amp. that has an XLR connector ,just like with a Mic.input on a mixer .
...if Ya want the tech. explan. then shoot me a pm.
Vic
Posted 2009-07-02 5:44 PM (#408873 - in reply to #408870)
Tru-balance was a marketing term applied to a short-lived Ovation pickup where the piezo elements were bonded into a synthetic comensated saddle, narrower than the original pickup but wider than the Thinline (which was introduced a little earlier) The Tru-Balance just about replaced the original pickup for a few years from the late 90's. The name alluded to it's "superior" string-to-string balance characteristics, not the fact that it required a balanced output. It was usually found on higher-end guitars some of which had the Optima preamp, which did have a balanced output but of course also had a regular unbalanced output. (By the way balanced configuration is 2 hots, one of which is 180 degrees out of phase, plus a common earth)
The Tru-Balance sounds a little different to the Original pickup, and is a little lower in output but I definately prefer the original tonally. In my experience the Tru-balance would "quack" long before the OPP. If anything the Tru-Balance, having less mass the the OPP was arguably better for the acoustic tone, but we're splitting hairs. The fact that the Tru-Balance is no longer available and lasted only a few years should tell you something.
Posted 2009-07-02 6:50 PM (#408874 - in reply to #408870)
My ramblings were based on the XLR that I saw on some gits. , hence the comment ..
" as I understand it , Tru -Balance = Balanced Config. " ..
,I was wondering if maybe Stereo was incorporated , but thought prob. not , ..
XLR has 1 ) Positive = Hot
2 ) Negative = Cold ( 180 Phase -shift yes )
3 ) Common = Ground
Let`s Not split hairs no ,...
So when Not Balanced , then what`s the XLR for ?
( Sorry PEZ , Do n`t have a git like that , only observed it from far away ,and Assumed something else )
Vic
Posted 2009-07-02 7:27 PM (#408875 - in reply to #408870)
Oh yeah , I get it ..
" Paul T : balanced output. It was usually found on higher-end guitars some of which had the Optima preamp, which did have a balanced output but of course also had a regular unbalanced output " .
So when I observed the XLR , it was correct to assume the Balanced -Config. , .. associated it with Tru-Balance , which , as pointed out , is something else ..
Vic
Posted 2009-07-03 1:42 AM (#408876 - in reply to #408870)
I have Tru-Balance on my 2000C and my CL12 ... both with the Optima. I can't tell you whether it's the pickup or the preamp, but they both sound great plugged in. But then, so do my other Ovations for the most part.
Here's a picture of what the Tru-Balance looks like:
As far as how it sounds, you can listen to the song Nowhere Man on my ning page here: bobbo\'s ning page . The acoustic guitar on the song is the 2000C with the XLR output going directly to the recording machine. Warning: I am a very crappy sound engineer so take it for what it's worth.
PEZ
Posted 2009-07-03 4:24 AM (#408877 - in reply to #408870)
July 2003
Time will tell.
The one is an Op-24+c
A little different sound might not be a bad thing.
Thanks
