Academy tuning machine repair.
Posted 2009-08-26 7:52 PM (#401046)
Subject: Academy tuning machine repair.
When I got the Academy from Seesquare, I knew there were a few issues with it, most notably the tuners were disintegrating where the strings contact the plastic barrels. I decided to try to do a repair job on them, and it worked out pretty well, so I thought I'd share the info. First, here's what they look like when they start to break.
I cut the old plastic barrels off with a side cutter, which was very easy to do...
That leaves you with this...
I went to Lowes and found these nylon bushings that were really close to the same size, although I had to drill the holes a little to make them fit tightly over the end of the shaft.
Posted 2009-08-26 7:55 PM (#401047 - in reply to #401046)
Subject: Re: Academy tuning machine repair.
Then I pressed the bushings on the shaft.
So it looks like this.
Just put it back together and a new set of strings. It is much more steel string friendly now with the smaller shafts.
Posted 2009-08-26 8:11 PM (#401048 - in reply to #401046)
That is sooo Cool. Lock this thread away in a file somewhere for future reference.
Great Going TJ!
Posted 2009-08-26 8:20 PM (#401049 - in reply to #401046)
Alrighty Jim! That answers my ol' POST.
Posted 2009-08-26 8:35 PM (#401050 - in reply to #401046)
Necessity is the mother. Oh,...of invention. I figured steel posts would be fine if you didn't use nylon strings. Originally, the 17 was set up to use either nylon or steel, but I'm pretty well stuck on steel strings. I would have put a bushing on both ends, but I figured the plate would support the outboard end, and it seems to work fine.
