1/4" cables
Fridave
Posted 2008-04-24 5:04 PM (#43082)
Subject: 1/4" cables
February 2008
Do you use a straight or right angle instrument cable comming out of your O ? Are the 1/4" outputs in the same places on most of the different models ? My 1612 location is slightly different than my 1717. If I remember correctly (it's been a long time) my 1612 came with a cable when I bought it new ! It was a right angle to straight very thin chord.
FlicKreno aka Solid Top
Posted 2008-04-24 5:07 PM (#43083 - in reply to #43082)
Subject: Re: 1/4" cables
I like the Angled jack..it`s just a personal preference.
Vic
..I also like Wireless -systems..
Posted 2008-04-24 5:10 PM (#43084 - in reply to #43082)
I use the Planet Waves circuit breaker right angle cables.
Posted 2008-04-24 6:23 PM (#43085 - in reply to #43082)
I prefer to use right angled plugs and then loop the cable through the strap attachment so that the cable doesn't pull out when I step on it.
The straight plugs scare me. If hit just wrong, it could stress the bowl and break it around the jack. One of the dogs broke the wife's good electric keyboard that way. He knocked the keyboard backwards and it landed on the plug, which broke the motherboard inside!
First Alternate
Posted 2008-04-25 10:38 AM (#43086 - in reply to #43082)
May 2005
(If you use a 1/4" cable, you have to stay pretty damn close to the amp)
The conventional wisdom used to be to avoid right angle plugs. But the quality of those available now make them preferable to the straight ones not only for convenience, but as FlySig mentioned, the damage that could result from lateral stress on the plug.
Posted 2008-04-25 11:46 AM (#43087 - in reply to #43082)
Al sent me a Monster jazz/acoustic cable with the OFC guitar, and it has been my primary instrument cable ever since. Oddly, lettering on the cable implies that it is directional with a straight plug for the amp/board end and an angled plug for the guitar end. Depending upon the type of guitar stand used, if any, the angled plug could interfere with the bowl resting on one of the bottom arms. This is easily overcome by swinging the cable a bit, but you have to be sensitive to it.
Posted 2008-04-25 11:51 AM (#43088 - in reply to #43082)
I haven't owned an angled plug for years, well before my first O acoustic. I may have to try that out.
Posted 2008-04-25 1:56 PM (#43089 - in reply to #43082)
I got the same cable that Prof talked about. I spent a fair amount of time experimenting with which end went where. I guess I should have read the labelling.
It's tough being an old lawyer when your eyes are too bad to read the fine print.
Posted 2008-04-25 2:17 PM (#43090 - in reply to #43082)
That must be those Polish cables that Al special-ordered . . .
Posted 2008-04-25 3:07 PM (#43091 - in reply to #43082)
No, those would be the ones where you have to plug the amp into the cable.
I did get a Polish label for the guitar case, though.
Fridave
Posted 2008-04-26 7:43 AM (#43092 - in reply to #43082)
February 2008
I also have one of the monster rt angle to straight (directional) cables. Mine has a directional arrow on it so a dummy like me would know which end to plug into what ! Yea gotta be careful when putting the 1717 in the guitar stand, sits right on the output, not an issue on my 1612 cause the plug is a bit more toward the back of the bowl.
