Adamas sound board attachment
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | Does anyone know what is used to attach an Adamas sound board to the bowl? I just received an 1881 that is loosing the bond between the carbon fiber face and bowl. I know the obvious suggestion would be to send it to the MS but I would prefer to not chance shipping this beauty all over the country. | ||
| Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | super glue or super glue gel would work I think. Don't know what they use at the factory these days. | ||
| stonebobbo |
Joined: August 2002 Posts: 8307 Location: Tennessee | Check the archives for "suspension ring". You'll find some pictures and discussion about how the top attaches to the bowl. | ||
| Patch |
Joined: May 2006 Posts: 4241 Location: Steeler Nation, Hudson Valley Contingent | Hi Jim, I was thinking super glue as well, but need to see exactly how it's separating. Get some pics to me and I'll fly them past John and Kim. But if the top is just a little separated from the suspension ring, then we should be golden. (I think.) Nobody knows better than Beal about these, so I'm feeling much less stressed about this than I did five minutes ago. | ||
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | I will try to do post pics in a bit | ||
| Patch |
Joined: May 2006 Posts: 4241 Location: Steeler Nation, Hudson Valley Contingent | Here are some links Jim. On the first, scroll down to Jerome's second post to see a cutaway photo of the soundboard and how it sits on the suspension ring. The second is self-explanatory. Suspension ring photo top assembly I would love if someone here would verify or improve what I'm going to type next, but it's how I would start. If it looks as if the top has just separated from the ring, you may be able to lightly sand the surface of the ring and use a hobby brush to "paint" and light coating of 60-second super glue to it. Then seat the top and apply even pressure for more than the minute minimum. | ||
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | Thanks Patch. I've seen all those photos and am familiar with the top ring assembly. I just need to know which adhesive would be correct. I am thinking a slower cure two part epoxy or polyurethane. Does anyone know which type for sure? I personally have never had much luck with CA type adhesives. Jim E. | ||
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | Forgot to add. I can't get a good close up photo that works. None of the cameras I have can focus close. Jim E. | ||
| Patch |
Joined: May 2006 Posts: 4241 Location: Steeler Nation, Hudson Valley Contingent | So is it a separation of the two flat surfaces? If so, I think this could definitely be a DIY as long as you're careful. Though I can't figure out why it would have separated. Heat or cold in shipping? Anyone? | ||
| 2ifbyC |
| Joined: December 2006 Posts: 6268 Location: Florida Central Gulf Coast | Originally posted by Patch: NY to CAL... Heat or cold in shipping? Anyone? Sorry to hear 'bout this! John or Kim will probably provide a solution. | ||
| FlySig |
Joined: October 2005 Posts: 4090 Location: Utah | Originally posted by Jim E: The stuff they sell in the grocery store these days is watered down. Too many people glued their finger to their eyelid. I personally have never had much luck with CA type adhesives. At Home Depot or a good hobby shop you should be able to get real CA that works. I recently glued the aluminum swoosh back to the top of my 2080 and the glue is quite strong and permanent. Reminded me of the old days with the original super glue where they advertised one drop would pick up a car. | ||
| bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | If Bill says super glue or super glue gel, I'd listen to him. | ||
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | Thanks everyone. I will try the CA in one section. If it holds I will use it on the rest of the separation. FlySig. You are 100% correct on the grocery store CA. I do a bit of woodwork (as a hobby) so I have a fresh bottle of LocTite precision max that should do the job. The problems I have had with CA in the past is the stuff seems to loose it's bond over time. Jim E. | ||
| Jim E |
Joined: December 2009 Posts: 79 Location: So Cal | The CA did the trick. The top is re-attached and perfect. Thanks again for everything Patch. Jim E. | ||
| Patch |
Joined: May 2006 Posts: 4241 Location: Steeler Nation, Hudson Valley Contingent | MAN! Am I glad to hear it. It's been on my mind all week. Now that I know that's squared away, I need to give John Budny a call. I didn't want to spend the money until I knew this was squared away, but he's got something of mine waiting to ship. ;) Enjoy that guitar. It sure is a nice one! :cool: | ||
