Best way to remove a plastic rosette?
twistedlim
Posted 2010-04-05 10:40 PM (#374981)
Subject: Best way to remove a plastic rosette?
November 2008
Thinking about a refinish project. Anybody know the best way to remove the rosette without damaging the top (or hopefully the rosette}?
Thanks
bvince
Posted 2010-04-06 7:53 AM (#374982 - in reply to #374981)
Subject: Re: Best way to remove a plastic rosette?
September 2005
Never tried that yet Rich. I have read some comments on it on this board recently though. Good luck!
Posted 2010-04-06 9:47 AM (#374983 - in reply to #374981)
6 oz C-4
Posted 2010-04-06 10:11 AM (#374984 - in reply to #374981)
That'll remove a lot more than the rosette. It will also remove the room where the guitar is located....
twistedlim
Posted 2010-04-06 11:19 AM (#374985 - in reply to #374981)
November 2008
Originally posted by Beal:
6 oz C-4
I like your style...
Darkbar
Posted 2010-04-06 11:47 AM (#374986 - in reply to #374981)
January 2009
Beal needs to take some lessons in subtlety
cholloway
Posted 2010-04-06 12:23 PM (#374987 - in reply to #374981)
He sure does... 3 oz. would be more than enough.
Besides, he said plastic rosette. Not plastique!
Have you considered a hot blow dryer or heat gun? Just to soften the glue.
Posted 2010-04-06 1:18 PM (#374988 - in reply to #374981)
Try smacking somebody in the head with your guitar.
That works sometimes, but you might have to soften it up with beer first. (beer. is there anything it won't solve?)
fletcher
Posted 2010-04-06 2:49 PM (#374989 - in reply to #374981)
March 2009
The rosette or the head?
twistedlim
Posted 2010-04-06 3:06 PM (#374990 - in reply to #374981)
November 2008
Heat sounds the most reasonable Colin. If not we could try the nuclear option.
Posted 2010-04-06 5:41 PM (#374991 - in reply to #374981)
yes
Glen C.
Posted 2010-04-06 6:07 PM (#374992 - in reply to #374981)
November 2009
If the finish on the guitar was applied after the rosette was installed you will have a tough time because you have to break down the finish as well as the glue. I would do the following
1. Very carefully score the rosette perimeter where it meets the top with an exacto knife or razor blade to break any bond to the top finish.
2. Apply heat gradually. You can use a heat gun carefully or you may want to use an iron with some cheesecloth or similar between the rosette and iron to protect the rosette finish.
3. Most glues begin to break down above 140 degrees. As the glue breaks down you will need to very carefully work a thin flat blade under the rosette. The blade needs to be about the size of a putty knife but thinner. Go slow, have patience and you should be successful.
Good luck
