Preamp only works with tuner on
uwep
Posted 2008-05-07 12:40 PM (#40650)
Subject: Preamp only works with tuner on
December 2005
Hello,
maybe someone of you can help me.
I bought a second hand Adamas W597 Melissa Etheridge, from 2002. When I connect the Guitar cable between the mixer to the guitar ( 1/4" ) sound only comes as long as the tuner is switched on. When tuner shuts down after some seconds also signal to the amp is down.
javascript:void(0)
Confused :
bauerhillboy
Posted 2008-05-07 12:47 PM (#40651 - in reply to #40650)
Subject: Re: Preamp only works with tuner on
Which preamp? Optima or Op24+C ?
uwep
Posted 2008-05-07 1:07 PM (#40652 - in reply to #40650)
December 2005
It is the Optima
uwep
Posted 2008-05-07 1:53 PM (#40653 - in reply to #40650)
December 2005
Hello,
me again - found out the problem myself.
I grabbed the cable which belongs to my Taylor K4.
It has a more contact.
Used a normal guitar cable - anything fine again.
Thanks
Uwep
Posted 2008-05-07 2:06 PM (#40654 - in reply to #40650)
That'll teach you about using that Taylor stuff.
uwep
Posted 2008-05-07 2:35 PM (#40655 - in reply to #40650)
December 2005
Sold that thing already last year - only couln'd find the cable that time - now I did!
xnoel
Posted 2008-05-07 3:16 PM (#40656 - in reply to #40650)
I had that same problem trying to use a cable with 3 contacts (can't remember what it is called)on my "T" with OP30.
Needed it with the alesis mini mixer to cancel hum. Took me awhile to figure it out.
