OP-30
mo36
Posted 2012-01-09 3:23 PM (#181)
Subject: OP-30
January 2012
Hi all and thanks for let me post here with a small problem.
I refit my old legend just for trekking purposes and put away the whole electronic, because the pickup (fatline) and preamp was damaged. Now I got an OP-30 incl. the proper 6-pin can and tried build in that guitar. The hole for the can was cut out from the body ok and the pickup was changed to a shadoww SH66 (not a thinline). My problem is how to connect the (mono) guitar plug to the can? The Pickup wire to the small jack fits. But now I have a 5-pin socket on the can and another jack.
From the former system I have only 3 wires coming from the guitar out (way to Amp).
No Original OP-30 Cables available here. So how can I hook up, without take the risk for crash the preamp? thanks in advance for your help and sorry for my unproffessional vocabulary
Harry
Posted 2012-01-13 6:20 PM (#182 - in reply to #181)
Subject: Re: OP-30
The other jack is a 3.5mm TRS socket which is the output hot and cold, plus the switch for the battery. You need to wire a TRS 3.5mm plug to a 6.35mm switched jack socket. Forget the multipin connector.
mo36
Posted 2012-01-14 3:18 PM (#183 - in reply to #181)
Subject: Re: OP-30
January 2012
Thanks a lot. It works fine now
Harry
