VIP Preamp question
scott lamperd
Posted 2010-11-30 5:52 PM (#360459)
Subject: VIP Preamp question
I just bought a Adamas 597 with a VIP preamp. It will not function on the xlr output without the
regular guitar cord being plugged in. Is this
normal? And yes, I do have the phantom power turned on on the mixer.
scott lamperd b c (before computers)
Posted 2010-11-30 6:11 PM (#360460 - in reply to #360459)
Subject: Re: VIP Preamp question
the phantom will not power up the preamp without a slight mod to the XLR cable. You need to connect the ground (Pin 1) to the XLR casing. This is known as a ground-to-shell short. Should work just fine one you've done what is an annoying and unnecessary mod. The Optima didn't need this and subsequent preamps shouldn't have needed it either
scott lamperd
Posted 2010-11-30 6:43 PM (#360461 - in reply to #360459)
Thanks Paul, I appreciate the help! Hope you have a wonderful Christmas.
bvince
Posted 2010-12-01 8:32 AM (#360462 - in reply to #360459)
September 2005
...Just a dumb question...but if it wasn't needed, why did they make them this way? To sell cables?
Posted 2010-12-01 9:30 AM (#360463 - in reply to #360459)
Paul's absolutely right. Annoying & unnecessary.
Scott, I've found a lot of XLR cables are already wired this way (ground to shell). If you have a continuity tester or ohmmeter it's easy enough to test it. On the female end (that plugs into the guitar) test between pin 1 and the casing. If there is no resistance, it should work.
scott lamperd
Posted 2010-12-01 10:32 AM (#360464 - in reply to #360459)
Thanks for the assistance. I'll get out my soldering gun.
Adamas 597
1989 8461
Aluminum neck Applause x 2
Newer applause in pieces
