What is the easiest way to remove a rosette?
Michael R. Winters
Posted 2011-01-14 7:24 PM (#357539)
Subject: What is the easiest way to remove a rosette?
September 2002
Ok Luthiers...
I want to replace the rosette on my boy's 77 CB.
It is intact but scratches and has a few little cracks.
What is the easiest or best way to remove the old one without tearing the top apart?
scott lamperd
Posted 2011-01-14 10:26 PM (#357540 - in reply to #357539)
Subject: Re: What is the easiest way to remove a rosette?
It's affixed to the top with a brittle glue. Start with the outside edge and very carefully lift it with a sharpened putty knife. Work towards the center of the hole. There is also a little lip under the end of the fretboard.
I use contact cement to apply the new one.
Good luck
scott lamperd b c (before computers)
Michael R. Winters
Posted 2011-01-15 2:35 AM (#357541 - in reply to #357539)
September 2002
I'll give it a shot, thanks again Scott.
bvince
Posted 2011-01-15 2:03 PM (#357542 - in reply to #357539)
September 2005
I haven't tried that yet, but you MAY want to heat it first with a blow dryer from a little distance. A LITTLE heat should make the adhesive soften up a bit and may help avoid chipping any of the wood off.
Michael R. Winters
Posted 2011-01-15 5:21 PM (#357543 - in reply to #357539)
September 2002
I had to put a considerable amount of pressure with my finger and then one little part popped up
I was able to wiggle a plastic putty knife under it and I eventually got it off in two pieces.
Now I just have to sand away the glue residue, wait for a rosette, & glue it on. :)
