Amp for both acoustic and electric?
Paul Blanchard
Posted 2011-01-28 7:21 PM (#357029)
Subject: Amp for both acoustic and electric?
I may do some concerts playing both electric and my Ovations. Any suggestions on an amp that sounds really good for both that doesn't have a price tag like the Rivera Doyle Dykes?
I've had Parkers, Godins, Hamers, etc. with both mag pickups and a bridge piezo, but never had an amp that worked equally well with both mag and piezo.
I could run electric through a stage amp and send the acoustic to the board, but can't predict a reliable monitor mix.
One other option is the better Variax electric, which has an acoustic patch. One amp would work, but it wouldn't sound like my Ovations.
Whatcha think?
Posted 2011-01-28 8:05 PM (#357030 - in reply to #357029)
Subject: Re: Amp for both acoustic and electric?
While Rockman gear itself is dated, the premise and method are still valid. The final stage (the amplifier to the speakers) is a FULL RANGE amp with FULL RANGE speakers. Then, put the appropriate pre-amp in front for Acoustic or Electric to switch between.
The actual choices of gear depend a bit more on your style. I played mostly electric. So I had a pair of Roland Bolt 60's with fuller range speakers than guitar speakers. I only used the clean channel so I got great "Acoustic" tone. I used Rockman pre-amps or ART or stomps or whatever to get my electric sound.
I'm guessing the Boss L1 series with the right pre-amp might make an excellent electric tone if you were playing primarily acoustic.
Also... when you say "electric".. that's not really saying much.
Anyway... hope that's some food for thought..
Paul Blanchard
Posted 2011-01-28 8:10 PM (#357031 - in reply to #357029)
Miles, thank you and good observation of ambiguity.
Point of clarification: "electric" = guitar with magnetic pickups. Right now I have Strats.
Posted 2011-01-28 8:11 PM (#357032 - in reply to #357029)
Such an amp does not exist, and whatever solution you come up with will be a compromise. Best bet is to get the best acoustic amp (or PA) you can afford and use amplifier simulation for the electric guitars. There's a bunch of digital modellers around such as the Line6 Pod and it's various clones, but for my money the SansAmp pedals sound and feel way better. They don't have the programability but they provide 1 killer tone with the abilty to morph it using the character function. I use one of the SansAmp "Character" pedals for Lap Steel (the "Blonde" Fender amp simulator) and it's killer, either into our Bose L1's or whatever the house provides
The other thing that's worth checking out is the iphone/ipad amp modelling Apps. I have Amplitude and intend to use that for our upcoming USA gigs instead of schlepping my entire Lap Steel pedalboard across the pond
6L6
Posted 2011-01-28 11:33 PM (#357033 - in reply to #357029)
Most O/M's I play my Model 1869 Custom Legend through some pedals (BOSS DM-1 Analog Delay and a BOSS CH-1 Super Chorus) into a '72 Fender Vibro Champ with a line out for the PA if needed.
Works great with either my Ovation or an electric guitar.
noah
Posted 2011-01-29 1:34 AM (#357034 - in reply to #357029)
Try one of these. Great for acoustic. Nice for clean electric. A pedalboard in via the return on the effects loop bypasses the acoustic preamp and feeds the power amp direct. The 12 inch is a Celestion V30. I've seen a few on eBay recently go for cheap.
Posted 2011-01-29 3:11 AM (#357035 - in reply to #357029)
Actually I guess my ambiguity was ambiguous.. :)
When I think electric, I think distortion, sustain, metal, rock etc.. That's a whole different set of frequencies then lets say Rock-A Billy, Jazz, or traditional Country.. all electric.
But... the premise still plays out. If you can get a great clean tone from your acoustic, there are a host of modeling amps to help you create something close to what you'll like for an "electric" sound.
Darkbar
Posted 2011-01-29 7:45 AM (#357036 - in reply to #357029)
January 2009
That's how I read Miles' question. There is a big difference between electric satin jazz, country twang, or death metal grunge/thrash. What kind of electric guitar music are you playing?
Paul Blanchard
Posted 2011-01-29 9:33 AM (#357037 - in reply to #357029)
Lots to think over, and I realize how narrowly I read Miles question. What kind of electric guitar signal the amp is asked to replicate is a big part of the equation. Back later, but thanks -- again -- for now.
Paul Blanchard
Posted 2011-01-29 9:34 AM (#357038 - in reply to #357029)
Style of music will vary, but mostly pop/rock and some country.
Posted 2011-01-29 11:19 AM (#357039 - in reply to #357029)
I used a Korg brand Tone Works modeling box for my electrics when playing in the church band through the PA. (Other brands such as Line 6 POD get excellent reviews though I have not personally used them.) The box makes for a nice DI solution as well as making a lot of different tones quickly available. Since we were a cover band, having the ability to change tones fast was really convenient.
The ToneWorks is a stereo box with mono input, so if your PA can take a stereo signal you can get stereo reverb and chorus effects.
The Ovations always get plugged directly into the PA via either a DI box in the venue or via XLR cable if the guitar has that output.
Another option would be to buy a small amp to use as a DI for your electric guitar. The amp becomes your stage monitor, and the modeling preamp sends the signal out to the house PA. I've done this, and Sara has done this a lot with her acoustic amp setup. We've never had a ground hum problem so far. If you want to buy an electric guitar amp anyway, look for one with a line out and the front end modeling for your electric guitar. Your acoustic guitar will still have to just DI into the PA system.
Posted 2011-01-29 1:16 PM (#357040 - in reply to #357029)
How will using one amp for both "predict a reliable monitor mix"?
Paul Blanchard
Posted 2011-01-29 1:33 PM (#357041 - in reply to #357029)
Damon,
One amp becomes my monitor and/or my source of stage volume. It's just a matter of being able to be heard on stage, and the sound system is likely to be way less than ideal due to being in Central America on a low budget.
Posted 2011-01-30 1:30 PM (#357042 - in reply to #357029)
I'm using a Genz Acoustic Pro clean with the tube preamp up all the way, and a pedal board in front. I, too, go back and forth with acoustic and electric guitars, and sometimes even on the same guitar (yeah, VXT!). I've also used a Vox AC15HTVLT1 hand wired class A model. I saw Kaki use a Fender Vibro King run clean with her pedals and she regularly switched between acoustic and electric models, liked her sound, so I figured something similar to her setup would do me just fine.
Posted 2011-01-31 10:38 AM (#357043 - in reply to #357029)
If you want to go with one amp, then Temp's method is the best. When you want to go electric, just plug in a sansamp. I recommend you look at two:
The GT2 or the SansAmp Para Driver.
As for the iPhone Apps, I have no idea.
