OP24+ problem
Stan L.
Posted 2008-05-15 9:10 PM (#39411)
Subject: OP24+ problem
Hello all;
I don't remember if I asked here already (I've been all over looking), so here goes.
I'm searching for the schematic diagram of the OP24+.
It only works as a pre-amp. Insert the EQ and you loose all output.
With some help, I found out how to remove the amp from the guitar, but a schematic would be helpful as I've already determined that the push button switch is NOT the problem.
If I have to, I'll reverse engineer the thing, however, the chip used in the EQ circuit has some unlisted house brand number on it which will make it much harder to do.
So, if there's any kind soul out there who has, and is willing to share, I'd be grateful.
Thanks, Stan
