Tuss rod adjustment?
reeko236
Posted 2011-04-17 1:23 AM (#353352)
Subject: Tuss rod adjustment?
April 2011
Hey guys, so the action on my ovation is pretty bizzare.. around the 1rst to 5th fret it is fine, but by the 12th fret the strings are about a whole centimeter away from the frets.
Is this my truss rod? Should I tighten it a bit as to make the neck bend farther back, reducing the height of the strings? I know the issue is not the saddle height, as the strings barely rest above the edge of the bridge on the current saddle set-up.
Any help appreciated. Thanks!
Posted 2011-04-17 2:06 AM (#353353 - in reply to #353352)
Subject: Re: Tuss rod adjustment?
No!
The truss-rod only adjust the "relief" over the middle of the fingerboard.
If your string-height gets progressively higher as you go toward the bridge you either need to adjust the saddle height or you need to reset the neck.
Nordicnorm
Posted 2011-04-17 1:22 PM (#353354 - in reply to #353352)
May 2010
Put a straightedge across the lower bout, 90 degrees to the strings/neck, up against the back of the bridge where the string buttons are located. Looking at the clearance out at the edges over the purfling will show you how much of a "belly" the guitar has developed. If your saddle is deep/low in the bridge, someone may have removed the shims under the saddle to compensate for this.
IMO up to 1/8" is fair on an ol guitar (help me out here friends), but I have had to deal with 1/4" on a newer LX, and it was quite a challenge.
Maybe a trip to the music store/luthier for a quick evaluation is in order?
