OP-Pro Studio vs. same with XLR
Epivox
Posted 2011-06-22 1:44 PM (#350736)
Subject: OP-Pro Studio vs. same with XLR
June 2011
Hi everyone,
I have just a question about the OP-Pro Studio. Is the XLR Preamp different? Or is it just a connection issue. Does the "normal" OP-Pro Studio provide XLR connectivity without using that - and can I upgrade this?
Cheers
Dieter
Posted 2011-06-22 3:01 PM (#350737 - in reply to #350736)
Subject: Re: OP-Pro Studio vs. same with XLR
Same electronics inside the preamp. The can in the guitar has a different circuit board to feed the XLR output. Instead of a single 1/4" output jack on the guitar, there is a little circuit board with both the 1/4" and XLR jacks. There is a different cable from the can to the outputs.
You can upgrade the can and jacks by just installing those parts.
bburg
Posted 2011-06-22 3:30 PM (#350738 - in reply to #350736)
August 2009
I think the can is also the same . I've upgraded about ten guitars to the OP-Pro-series preamps and all cans had the connection for the XLR-unit. But there were two different XLR-units, one for the OP-Pro with phantom-power and the one for OP-Pro-Studio and VIP-5 without phantom-power. The only can (with 8 connectors inside) I know without the XLR port is from the iDea-preamp. It has a little jack for the AUX input. But the iDea works fine in all cans using the 1/4" jack for output and all preamps are working in the Idea-can, except of the OP-Pro. I don't know why, but mine does not work in the Idea-can.
Bernie
Epivox
Posted 2011-06-22 5:00 PM (#350739 - in reply to #350736)
June 2011
Oh yes, this was the thing I forgot to ask - the phantom power!!! This is the essential issue I need. So if I have the OP-Pro Studio (in a 2077LX) and I want to use an XLR with phantom power - what to do (if possible)?
Dieter
Posted 2011-06-24 10:33 PM (#350740 - in reply to #350736)
Phantom power goes in via the XLR jack. So you need an external preamp or mixer which supports phantom power and the XLR. Just turn on the phantom power and you should be good to go. You may need to plug something into the 1/4" output jack as well. Any old mono 1/4" plug will do, it doesn't even need to be connected to a cable.
I can't remember if the 1/4" plug is required for the Studio, it is required for the VIP unless you have an XLR cable with the correct pin soldered to the body of the plug. Al sells the correct XLR cable for this.
bburg
Posted 2011-06-25 3:15 PM (#350741 - in reply to #350736)
August 2009
FlySig is right, but the only preamps I know you can use phantom power with (working without the battery) are OP-Pro, OP-50, Optimax and Optima. All others will work with a XLR cable if supported, but it will not feed the preamp.
Bernie
PEZ
Posted 2011-06-27 12:51 PM (#350742 - in reply to #350736)
July 2003
Dieter
no phantom power on those
titti
Posted 2013-10-07 3:55 PM (#477784 - in reply to #350742)
January 2011
...... I found this old thread. Pez, can you explain better? If the electronics of the preamps are the same , the can has the PCB XRL ( see photo), and the bowl has the XRL outpout , why not phantom power ?
PEZ
Posted 2013-10-14 2:44 PM (#477965 - in reply to #350736)
July 2003
It runs off 9 volt batter only. Its a balanced line XLR, not a PCB XLR.... this is what it looks like http://s219.photobucket.com/user/pezcleo/media/55.jpg.html?sort=3&o...
Edited by PEZ 2013-10-14 2:48 PM
titti
Posted 2013-10-15 4:41 AM (#477983 - in reply to #477965)
January 2011
PEZ,this is the inside of the OP-PRO-Studio can :see,there is a PCB.For the Phantom alimentation ,I believe.Or not? P.S.:I see also your photo,there is a old Optima preamp,probabily not for Phantom alimentation....
mrdoopey
Posted 2014-03-25 1:17 PM (#483452 - in reply to #350742)
October 2011
PEZ - 2011-06-27 12:51 PM
Dieter
Matt Smith says in this video https://www.youtube.com/watch?v=BxSmU5e_VeI that OP-Pro Studio in a 2077LX IS phantom powered (its at the 3:27 mark), but then again he isn't using the XLR jack at all in demonstation video. So he is wrong then?
bburg
Posted 2014-03-26 2:09 PM (#484493 - in reply to #350736)
August 2009
Yes, he is wrong! I've upgraded nearly all my "old" guitars (1614, 1615, 1624 and the 1627 I sold) to OP-Pro-Series preamps, all with XLR Units with Phantom.power, but only the Preamps I listed before are able to work with it.
Bernie
