Does "Scratch Remover" actually work?
dweezil
Posted 2008-06-10 7:52 AM (#35534)
Subject: Does "Scratch Remover" actually work?
Has anyone one ever tired this and got successful results? Or would rubbing goose fat into my Ovation have the same effect, i.e. not remove scratches?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=320261047...
AussieJames
Posted 2008-06-10 8:17 AM (#35535 - in reply to #35534)
Subject: Re: Does "Scratch Remover" actually work?
June 2007
Dweez,
Some on here might tell you where to rub the goose fat :D
Here is a previous thread on the subject
Scratch remover
Cheers
AJ
Posted 2008-06-10 8:54 AM (#35536 - in reply to #35534)
I bought a jar and put a coat on two guitars that showed some wear. The directions suggest repeated applications for the most effective results. I haven't had time to go back and put on a few more coats, but after the first coat, there was a noticeable improvement. I don't know about actually removing scratches. I think it just rounds the edges and fills in the scratch like any other good furniture polish/wax. If it removes swirl marks as claimed, then the stuff is likely taking off a thin layer of clear coat so you have to be careful with it, just like polishing out a car finish. One thing very unique...it smells like some type of fruity perfume, but the odor dissipates.
Posted 2008-06-10 10:41 AM (#35537 - in reply to #35534)
You must use a particular brand of goose fat, not available in the UK and we're not going to tell you what brand it is.
If you decide to use scratch remover instead, it is like a very fine polishing compound. It doesn't fill in the scratches, it sands the rest of the finish down to match the scratches, so be careful.
Posted 2008-06-10 10:48 AM (#35538 - in reply to #35534)
". . You must use a particular brand of goose fat, not available in the UK
and we're not going to tell you what brand it is . ."
Well Done, Counselor.
dweezil
Posted 2008-06-10 10:50 AM (#35539 - in reply to #35534)
Funny! OK thanks...
Mitchrx
Posted 2008-06-10 10:53 AM (#35540 - in reply to #35534)
I've used Zymol car wax with good results.
Posted 2008-06-10 11:10 AM (#35541 - in reply to #35534)
I told ya there was a price to pay!
I just received some of that 'majic' scratch remover yesterday. Haven't had a chanced to try it yet.
Stay tuned...
BTW, foie gras doesn't work!
Posted 2008-06-10 11:44 AM (#35542 - in reply to #35534)
Meguiar's makes a scratch remover for cars. I've used a 3M product on my guitars with decent results. Don't know if you can get either of those in the UK, but I think either of them are a finer mix than polishing compound. A pure car wax will not have any polish in it and will not take out scratches. Car "polish" (as opposed to "wax")will generally have some abrasive in it and will take out fine scratches. I have some very heavy pick scratches on one of my Ultra GSs that didn't come out with the scratch remover and I didn't want to go any deeper. It takes a fair amount of work and it's a bit scary to rub hard enough to get any results. You can also get fine sandpaper. I use 2000 grit, with a fairly generous supply of water with a bit of soap in it, but this is definitely not for the faint of heart.
I figured you were begging for a sarcastic response on the goose fat, dweezil.
Posted 2008-06-10 12:02 PM (#35543 - in reply to #35534)
I think its called Bonnet Lacquer in the UK...
Posted 2008-06-10 12:15 PM (#35544 - in reply to #35534)
Isn't that Hair Spray?? . . .
Posted 2008-06-10 1:04 PM (#35545 - in reply to #35534)
:D
Posted 2008-06-10 1:55 PM (#35546 - in reply to #35534)
If it was hair spray, I'd have no use for it. Anyone know of a good brand of forehead polish available in the US? Mineral oil is too slippery, so my hat won't stay on.
maxdaddy7271
Posted 2008-06-10 1:59 PM (#35547 - in reply to #35534)
March 2006
Silly, that's what goose fat is for!
Posted 2008-06-10 4:49 PM (#35548 - in reply to #35534)
Mark, if ya wear a hat, then why the polish? Top finish checking?
Posted 2008-06-10 5:30 PM (#35549 - in reply to #35534)
I still feel compelled to take my hat off when I enter a building or when I get my picture taken. I haven't come to grips with how bald I am yet. Actually, I need something to reduce the glare.
Second purpose is that it reduces wind resistance when I drive with the top down. The flip side to that is that I get sunburned if I don't wear a hat. Getting old sucks.
AussieJames
Posted 2008-06-10 5:41 PM (#35550 - in reply to #35534)
June 2007
Yeah true!!
But getting older sure beats the alternative
