Must I be Einstein to upgrade preamps?
weighn5
Posted 2005-12-29 4:50 AM (#331848)
Subject: Must I be Einstein to upgrade preamps?
December 2005
The square op24+ would be replaced with op30/op40. Is it true modifying fibreglass body more difficult than wood? About How much $$ for op30 parts only? Any other comments appreciated.
Posted 2005-12-29 6:26 AM (#331849 - in reply to #331848)
Subject: Re: Must I be Einstein to upgrade preamps?
Check with the Factory (Kim Keller, next week, they're closed right now). They do a very nice job. Might even call it professional.
bvince
Posted 2005-12-29 7:11 AM (#331850 - in reply to #331848)
September 2005
As far as hole modification is concerned, it obviously depends on what you're replacing and with what, and how confident you are in your ability to use a Dremmel Tool. I use that Dremmel Tool with the extendable tool snake and the endless supply of bits (cutting disks, router bits, sanding drums, etc.) You need to have a good eye and the ability to precisely mark your cutting area. I don't consider it a difficult thing, but I would probably recommend that most people leave it up to the pros. If you're not 100% sure you could do it, don't.
bauerhillboy
Posted 2005-12-29 1:06 PM (#331851 - in reply to #331848)
I had a guitar with the rectangular preamp and asked Kim what it would cost to put an Op pro in it. He told me they hadn't figured out how to do that yet. That was a year ago. They may have figured it out by now, but if the service dept. didn't know what to do at that point I would imagine it would be a risky thing for one of us to try on our own. John <>{
Posted 2005-12-29 1:25 PM (#331852 - in reply to #331848)
More than likely the square hole isn't in the right position for the newer OP's, which follow the body contour.
Posted 2005-12-29 2:30 PM (#331853 - in reply to #331848)
"imagination is more important than knowledge" albert einstein
this is from a poster that hangs over my desk
Posted 2005-12-29 2:46 PM (#331854 - in reply to #331848)
"Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity." -- Albert Einstein
Posted 2005-12-29 2:52 PM (#331855 - in reply to #331848)
"Where the f*ck is my COMB??!!"
- Albert Einstein
Northcountry
Posted 2005-12-29 4:15 PM (#331856 - in reply to #331848)
What the f*ck is a COMB?
-Albert Einstein
Abendicum
Posted 2005-12-30 8:39 AM (#331857 - in reply to #331848)
June 2004
North Country:
Either it migrated between his cheeks, when he sat down, or he wants to straighten his mangy hair to meet the "pretty girl"... (or a combination of both)
(Be thankful Lamas weren't in the joke...)
AB
Posted 2005-12-30 9:40 AM (#331858 - in reply to #331848)
Einstien had a comb up his butt?
Did I miss something here?
Posted 2005-12-31 8:11 AM (#331859 - in reply to #331848)
"Virginia is for Lovers" ...that's Relativity
Have you thought about the OP-X instead of the 30/40
Posted 2005-12-31 10:43 AM (#331860 - in reply to #331848)
I always thought that was "Virginia is for loving your relatives"...
