How to prevent bridge lift?
dweezil
Posted 2008-06-16 3:08 PM (#34462)
Subject: How to prevent bridge lift?
Was reading a recent forum post about a guitar that had suffered from bridge lift.
Started me wondering...
If I look closely on both my 84C and 868 it appears that there is a SLIGHT raised 'hump' on the sound board behind the bridge. So...
1. Is this natural / normal?
2. Should I worry (more than I ought to)?
3. How can one prevent it (short of detuning after each session)?
4. Bearing in mind I play in tunings (i.e. Open E) that put more tension on the neck than regular tuning am I more likely to suffer from stink foot, oops sorry I mean bridge lift?
I use 11 - 50 gauge strings so perhaps the 'damage' was done ny previous owners.
Posted 2008-06-16 3:14 PM (#34463 - in reply to #34462)
Subject: Re: How to prevent bridge lift?
slight hump behind the bridge is rather normal.
Posted 2008-06-16 3:49 PM (#34464 - in reply to #34462)
Down here, you just don't use the on-board marine horn to awaken the bridge tender...
G8r
Posted 2008-06-16 3:54 PM (#34465 - in reply to #34462)
:D :D :D
I was gonna say "lower the mast, raise the keel & wait for low tide" but ya beat me to it...
Posted 2008-06-16 3:56 PM (#34466 - in reply to #34462)
A small amount of hump is normal.
Posted 2008-06-16 5:26 PM (#34467 - in reply to #34462)
Which is what I keep telling my wife.
dweezil
Posted 2008-06-16 5:46 PM (#34468 - in reply to #34462)
you guys...
GlennAllenHessSr
Posted 2008-06-16 8:17 PM (#34469 - in reply to #34462)
so who decides what a small amount is? and why only a small amount?
Posted 2008-06-16 8:27 PM (#34470 - in reply to #34462)
more than a small amount of hump in the top means that standard adustments, such as bridge saddle height reduction will eventually, depending on neck-pitch, no longer fix a high action. Little or no top bulge generally means the guitar is over-braced and wont sound great. Too much top bulge generally indicates structural problems. Too little/too much/just right is a variable depending on the particular age, condition, geometry, storage conditions, maintainance, player perception, action and feel preference of each guitar. If the Bridge glue-seam is failing that is not normal and is a separate issue which should be fixed, even if it happens on a bridge that is bolted and glued
GlennAllenHessSr
Posted 2008-06-16 8:37 PM (#34471 - in reply to #34462)
so there's a difference between a "good hump" and a "bad hump" ?
Posted 2008-06-16 8:39 PM (#34472 - in reply to #34462)
I didn't know you'd met my wife.
BTW, We're taking wood tops here. Carbon fibre tops tend to stay pretty much as they were built.
