Pickup for Pacemaker
Bamse
Posted 2009-10-31 3:39 AM (#286828)
Subject: Pickup for Pacemaker
October 2009
WANTED: I have just bought an Ovation '78 Pacemaker on eBay. I need to install a pickupsystem in it as I will use it in a concert band. Can anybody advice me what equipment to install, and where to buy it? Original Ovation equipment is preferred.
Your help is highly appreciated.
Gallerinski
Posted 2009-10-31 10:10 AM (#286829 - in reply to #286828)
Subject: Re: Pickup for Pacemaker
Buy an Ovation thinline pickup from the factory.
Posted 2009-10-31 11:14 AM (#286830 - in reply to #286828)
Has the critter had a preamp in it, in the past? What's the model #- 1115, or 1615?
Posted 2009-10-31 9:33 PM (#286831 - in reply to #286828)
+1
Posted 2009-10-31 11:11 PM (#286832 - in reply to #286828)
If it didn't have a pickup to start off with, will the bridge handle any pickup? I played an early one last week and although it didn't have a pre-amp, it had some sort of a pickup, that actually sounded pretty good, however, it didn't appear to be an Ovation pickup as it just has a single bone bridge. I'm guessing the pickup is some sort of soundboard pickup just mounted underneath.
Posted 2009-11-01 7:27 AM (#286833 - in reply to #286828)
The last 1115 that I had, I installed an OP24+C with an Ovation thinline pickup and it sounded great.
standing
Posted 2009-11-01 11:16 PM (#286834 - in reply to #286828)
December 2008
Did the thinline fit in without any modifications other than the hole for the wire?
Is it possible to use a thinline pickup with a more modern OP-series preamp?
Since I am already asking dumb questions that illustrate my frightening lack of knowledge, I've always wondered; Are the pickups for Ovation (or anyone's) 12-stringers identical to the 6 string versions?
twistedlim
Posted 2009-11-04 9:45 AM (#286835 - in reply to #286828)
November 2008
All you need for the thinline is a hole and a new saddle. The thinline is the width of your slot in the bridge. You will need a new saddle that is scalloped out on the sides to fit into the thinline pickup. As far as the rest of the electronics go you can do that however you want. My 1115 has the thinline and just without any volume or tone controls. I got it from Glenn and he said that they did not want to put big hole in that nice shiney bowl so all I have is a small screw to hold the battery in place.
standing
Posted 2009-11-04 3:56 PM (#286836 - in reply to #286828)
December 2008
Thanks Twisted, for the answer AND the nice photos to illustrate it…
I thought the pickups were actually glued to the bottom of the saddle and were therefore all one- piece, your photo seems to show that is not necessarily the case…
