Buzz from battery compartment
TAFKAR
Posted 2008-08-20 3:01 AM (#25349)
Subject: Buzz from battery compartment
I started noticing a buzz when I played a C# on the A string. At first I thought it was something resonating outside the guitar, but then I realised it was coming from within. I took the manhole cover off but couldn't find the source. Then I took the battery compartment out and it disappeared. I put the battery compartment back in and it seems fixed.
The preamp is an Optima which has a separate battery compartment. Has anyone else had this issue? I'm hoping it doesn't reappear, but am thinking of putting a piece of cardboard under the battery, using the theory that the springs which push on the terminals are the source of the vibration.
John B
Posted 2008-08-20 9:18 AM (#25350 - in reply to #25349)
Subject: Re: Buzz from battery compartment
January 2004
You may want to make sure all of the screws that hold the can in place are tight.
Posted 2008-08-20 9:40 AM (#25351 - in reply to #25349)
when it's appart tap it with something and see if you can get the rattle then. might help in tracking it down.
