broken neck
benzook
Posted 2006-01-07 3:08 AM (#270214)
Subject: broken neck
Does anyone know if or how I can remove neck from celebrity 026.I hope to replce it with neck from my cc57 with smashed body. Thanks
Posted 2006-01-07 9:07 AM (#270215 - in reply to #270214)
Subject: Re: broken neck
if celebs have a bolt on neck it should be reletively easy. Look into the guitar (you might need a small mirror) at the neck block. How many bolts do you see??
benzook
Posted 2006-01-07 9:33 AM (#270216 - in reply to #270214)
There seems to be a piece of wood covering bolts though I can't be sure without removing it.I'd hate to go to all the trouble to find that neck doesn't bolt on.It's like a block of wood but then if you feel it seems to be a box that is glued together.I need some mice with chisels if anyones got some.
bauerhillboy
Posted 2006-01-07 12:00 PM (#270217 - in reply to #270214)
The construction methods used in overseas Ovations are very different from USA models. I think the reason for this is that, while Ovation specs the guitars, some details are kind of up to the factory that builds them (along with who knows how many other brands of guitars being made in that same factory). If I remember correctly seeing a Celebrity neck seperated from a body, the joint was a VERY crude mortice-and-tenon thing that, once torn apart, would be too much of a mess to do anything with. I'd say pull the 026 apart and see if it looks workable, but be mentally prepared to hit a dead-end. If that's what happens, don't be too disappointed; remember that these guitars are built to a pricepoint that really doesn't allow for easy future repairs. Sorry for being too verbose...this is my first adult conversation of the day. John <>{
dougr
Posted 2006-01-07 4:27 PM (#270218 - in reply to #270214)
from the owners manual with my ovation celeb, the newer ones have a dove tail joint, which when loosened , would slide up,i guess i dont know for sure, just trying to help..
benzook
Posted 2006-01-07 6:45 PM (#270219 - in reply to #270214)
Does it say how to get to bolts?I guess I still need those mice maybe with little jackhammers.Thanks for the replies.
Posted 2006-01-08 10:28 AM (#270220 - in reply to #270214)
If it is a dovetail, it will need to be steamed off. This is a fairly common techinque for luthiers. You could have a pro swap the necks, if they are compatable...
