The Ovation Fan Club | ||
Random quote: "Believe me when I say that some of the most amazing music in history was made on equipment that's not as good as what you own right now." - Jol Dantzig |
Stringing a Slothead
Forums Archive -> The Vault: 2008 | Message format |
JeffreyD |
Joined: September 2004 Posts: 777 Location: East Wenatchee, WA | I have discovered a new level of guitar frustration. It's only been a few years and a couple of good picture tutorials that I finally conquered stringing a "peg head" guitar. I now look forward to stringing my 1537 and 2080 as I can spend more time cleaning and primping on it, than the actual stringing. Enter the 2008C and the beauty of the slothead. YIKES.... This is not as easy a task as I thought it would be. Got it done, but my one major concern is that the G string is less than the width of a piece of paper from touching the TRC. I do NOT want to leave any marks on the 2008. So....how about some of the expert advice from this group on stringing a slothead so I can become proficient. | ||
GlennAllenHessSr |
Joined: April 2008 Posts: 498 | on my slots I string the Es wrapping toward the center, and all others outward... never had any trouble with clearance on the trc that way, even on carved ones. don't know if it's proper to string the e strings like that, but was told by a luthier it helps with the break angle. hope that helps, Glenn | ||
MusicMishka |
Joined: March 2005 Posts: 5563 Location: Blue Ridge Mountains | Back in the Day I could restring and retune my 1615 in under 20 minutes...ready for the next set... I could sill prpbably come close...wish I had a dollar for every restring... :rolleyes: | ||
Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | They are just a pain in the ass, no two ways about it. Advice, don't restring them often. | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | I've found a great method... very quick, stable and easy to learn... you'll never go back... | ||
Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | what is it, just buy a new one every time? | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | The worst is my Folklore. It's nice not to have to tie the bridge end, but they still used the same tuners then as on the nylon string guitars and I have a hell of a time getting the high e to stay on there. My Country Artist sits right now with a string that came unwound. I've got about 10 extra sets of steel strings, but no decent classicals. I just play other guitars instead. The only bigger pain in the ass is Jeff. | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Step 1. With guitar on a table or the headstock in your lap, Position the hole in the tuning post vertically toward floor and ceiling. Step 2. Thread string end down through the post hole from ceiling to floor. Pull all slack out and keep the sting as tight as you can. Step 3. Wind the end of the string (that is facing the floor) back up over the post to the backside (or headstock side of the post) Step 4. From the inside out, tuck the string end under the string that goes down through the post. Step 5. Pull tight to "lock" it between the string and post. Wind the tuner to remove any other slack. Cut excess leaving about a 1/4 inch. If you've kept the string fairly tight though-out the process, it will not slip and will tune to pitch in just a coupla twists of the tuner button. After you've done it once or twice you'll get fast and can do it in any position. (Freebie) | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | I'll take back what I said about you being a pain in the ass, Jeff......if you come over and restring my Country Artist. | ||
Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Jeff, you've adapted my* peghead stringing technique to slotheads! Excellent! Mark, it'll work. When I do it on pegheads I can bring the string up to pitch with less than 1/2 turn of the post, and it never slips, as it can with a bunch of windings on the post. *well, ok, it's not my technique, but it's how I teach people to restring... | ||
Gallerinski |
Joined: May 2008 Posts: 4996 Location: Phoenix AZ | With a little practice a slothead is no more difficult to string than a paddle stock. You just need to be careful to 1) double back and lock the strings, and 2) cut the ends to length so you don't accidently scratch the wood. Dave | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | ... s'ok Mark, I've learned to live with myself... I'll draw a picture and post it so folks can see it... | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | with this method you get no slippage and there's not even a full wrap around the post, so there is very little winding of the tuner | ||
bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | I use a little gun-shaped cordless driver I got from lowe's (Cobalt Lithium Ion 3.6V) to do the unwinding and winding. I wind all strings toward the outside, and I wind all the string I can without it hitting the outside of the headstock. I don't really concern myself with the 2 outermost strings, but all the rest get maximum winding. John <>[ | ||
bauerhillboy |
Joined: February 2004 Posts: 1634 Location: Warren,Pa. | The max winding addresses the issue of hitting the center of the headstock. John <>{ | ||
Capo Guy |
Joined: December 2004 Posts: 4394 Location: East Tennessee | Here's a page from an old Ovation manual I got with my first Country Artist. | ||
Beal |
Joined: January 2002 Posts: 14127 Location: 6 String Ranch | why not just have someone else do it? | ||
PEZ |
Joined: July 2003 Posts: 3111 Location: Nashville TN. | AH yes the reason for the guitar tech on the road crew. | ||
TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | So changing strings on slotheads is a new skill to learn. I'm buying a slothead because the guitar I want has a slothead. For those who would order a custom guitar with a slothead, what is the advantage/attraction of the slothead itself? | ||
PEZ |
Joined: July 2003 Posts: 3111 Location: Nashville TN. | Originally posted by MusicMishka: I can't do a 6 string that fastBack in the Day I could restring and retune my 1615 in under 20 minutes...ready for the next set... I could sill prpbably come close...wish I had a dollar for every restring... :rolleyes: | ||
sycamore |
Joined: March 2007 Posts: 698 Location: Cork, Ireland | Originally posted by The Artist (FKA Richard): I wondered that too. It looks more 'vintage' ? Or it's a neater way to accomodate 12 machine heads?...For those who would order a custom guitar with a slothead, what is the advantage/attraction of the slothead itself? | ||
Trader Jim |
Joined: June 2006 Posts: 7307 Location: South of most, North of few | You guys are PUassy's All you got to do is think at 90 degrees from what you're used to. It's easy. Just put the guitar in a herc stand, get a string winder, and get to it. Shouldn't take more than 20 min start to finish. (man, this thread takes two screens to view) :eek: | ||
Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Jeff's Mac seems to be unable to resize images... | ||
TAFKAR |
Joined: April 2008 Posts: 2985 Location: Sydney, Australia | He just made it really big so those with crappy PC screens could see it through the pixelated haze. | ||
Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | I just didn't realize is was that big (the .ning site doesn't show them full-sized) until it was posted here. Some where between ning and here it gets a good dose of androstenedione | ||
Jump to page : 1 2 Now viewing page 1 [25 messages per page] |
