Heat damaged 1621-4
kb1fvx
Posted 2006-03-26 5:11 PM (#260458)
Subject: Heat damaged 1621-4
March 2006
Hi folks, I have a 1621-4 with ser. #6832. I want to know what finnish was used on it? Also can I still buy a bridge for it?
Posted 2006-03-26 6:51 PM (#260459 - in reply to #260458)
Subject: Re: Heat damaged 1621-4
Welcome.
The finish used is a Polyurethane. Tough but difficult to repair once damaged.
Ovation Customer Service should have a replacement bridge as well as repair services for your instrument.
Posted 2006-03-26 7:16 PM (#260460 - in reply to #260458)
Wood-one, 'Zat true ??? I though there was talk here (too lazy to search) that it was poly-uro-cryano-acetate or some such gobble-d-goop. That's why you use superglue to seal cracks ??? I could just be dreaming, I guess.
kb1, something to beware of, if the top is damaged due to exposure to heat you better get a mirror and check inside. The braces could have also come un-stuck. The horse never planned on you exposing the thing to high temps. Good luck, and I hope it turns out OK.
Posted 2006-03-26 10:01 PM (#260461 - in reply to #260458)
I believe Bill said Polly-your-a-thing at one time. Cyano- is the prefix for Super Glue.
I know that Ovation finish is a Poly-epoxy. Once joined forever solid.
kb1fvx
Posted 2006-03-27 6:09 AM (#260462 - in reply to #260458)
March 2006
Thanks folks, I bought it cheap. And yes, I looked at the inside first thing, All ok in there. One more question, did they finnish the top before, or after the bridge was set? You've helped...
Thanks again, Mike
Posted 2006-03-27 7:21 AM (#260463 - in reply to #260458)
I beleve the bridge is attached wood-to-wood, not wood-to-finish, if that's what you mean.
TWA
Posted 2006-03-27 8:06 AM (#260464 - in reply to #260458)
The way I've seen it through pictures is the top is finished and then the bridge position is routed out.
Posted 2006-03-27 11:08 AM (#260465 - in reply to #260458)
I think, but could be wrong, that the routing of the bridge area is fairly recent with the advent of cad cam equipment. I think older guitars have the bridge glued to the finish on the top.
