plug in problem with 1998 adamas 1687
| denwal |
Joined: August 2006 Posts: 5 Location: Lancashire, England. | Hi, this is a first post from me so I will give a little background. An Ovation owner since 1976 ( a balladeer ) recently ,reluctantly sold to help purchase a 1998 Adamas 1687. My god what a difference!! only problem is, when I plug in to my Laney valve amp the tuner lights seem to be going through some kind of programmed routine and then the pre amp switches its self off with a loud click.I have installed a new battery and tried various knob twiddling but cannot suss it :confused: .Does anybody have an idea what is going on, any help would be much appreciated. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Welcome to the OFC, denwal! 1687's are fantastic guitars. Should have the Optima tuner. Are you plugging in using the 1/4" or the XLR? | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | Welcome denwal! various knob twiddling but cannot suss it That little phrase gave notice of your general location before your profile could. I don't have your answer but you can be sure someone here will. We have a good number of members here from your side of the pond. | ||
| johnny cash |
Joined: July 2006 Posts: 149 Location: gods country..west virginia | welcome denwal | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Could be component failure in the preamp. Try talking to the service dept at JHS. www.jhs.co.uk If you bought the guitar used it won't be covered under warranty, but they have replacement preamps. If they insist you go through a dealer drop me an email, I have an account with them through my business and can order spares for you. | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | Could this be a manifestation of the preamp not recognizing phantom power due to XLR ground connections? If not already, try using 1/4 inch to your amp. If already doing this, listen to Temp. ignore me. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Does the preamp only do this with a jack plugged in, or can you use the tuner normally when there's no cable plugged in? | ||
| denwal |
Joined: August 2006 Posts: 5 Location: Lancashire, England. | Thanks for the great response all of you. i have only used the 1/4 jack socket,I didn't even know that you could operate the tuner just on the battery alone!! so much for all those years having a model 1111 non electric. When I used the tuner unpluged, after a short time the green light flashes and then the unit shuts down, probably to save battery power? am I right on this. If I plug in to the amp it is again shutting down, this does sound like PT's explaination could be right. I'll contact JWS tommorrow and come back. regards | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | The tuner has an auto-off function. From memory it shuts down after about 1 minute, but should not shut down the preamp at the same time. | ||
| ChatMan |
Joined: August 2004 Posts: 604 Location: Tampa, FL | This sounds something like a dirty/bad connector in the plug. This is exactly the behavior I got when I had an Optima plugged in using an incompatible XLR. when I turned the tuner on, the preamp would work until the tuner turned off. For this to happen using the 1/4 inch I think might just be dirty contacts that sense the presence of the plug. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Dirty contacts sounds right. Also sounds like Jeff's address book. | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | ![]() | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | ![]() | ||
| denwal |
Joined: August 2006 Posts: 5 Location: Lancashire, England. | PT. Waiting for a reply from JHS. Interesting posts on dirty contacts. On my way out to get some switch cleaner. thanks chatman/ waskel | ||
| denwal |
