Need Ovation Tech in PA
mjoforiam
Posted 2006-11-27 7:56 PM (#230089)
Subject: Need Ovation Tech in PA
September 2004
Anyone know a good repair tech in Harrisburg, PA or nearby? I have some electronics issue.
Posted 2006-11-27 9:08 PM (#230090 - in reply to #230089)
Subject: Re: Need Ovation Tech in PA
What is your "electronics" issue?
You are an 'early' member....
Will Vic Litz do? Check them out.
If not, they will direct you to a reputable shop...
Posted 2006-11-27 9:12 PM (#230091 - in reply to #230089)
Welcome MJ...
Wow... looks like you have lurked for over two years before posting.
Glad you finally jumped in.
mjoforiam
Posted 2006-11-28 5:52 PM (#230092 - in reply to #230089)
September 2004
I think my issue has really been a problem from the get go, it is out of warranty now... go figure. I didn't notice it because it always worked in the setup I was using for some reason, when I changed set ups and then tried other amps, or effects I noticed that the guitar was having problems and now it won't work even with the set up that it did before so it has gotten progressively worse. The problem is that the signal from the guitar is not reaching the amp or effect, it is almost like the same problem when you have a bad cord and you would wiggle it and it will sometimes work. I had it checked earlier with a local shop and they could not find the problem, that is when it worked off and on, but now it is really bad. I think it might be inside of the op pro amp but I don't know for sure, all other contacts appear to be ok. So that is my problem.
