How do you patch a hole in fiberglass bowl??
Bluebird
Posted 2002-06-12 10:49 PM (#221195)
Subject: How do you patch a hole in fiberglass bowl??
I am going to remove a non-original preamp and volume knob from my Glen Campbell six-string acoustic and need to know how to patch the remaining hole in the bowl. Anyone ever done this? Are the 'shiny bowl' guitars actually laquered?
Wayne
Posted 2002-06-12 11:06 PM (#221196 - in reply to #221195)
Subject: Re: How do you patch a hole in fiberglass bowl??
bondo maybe?
Posted 2002-06-12 11:16 PM (#221197 - in reply to #221195)
You know Wayne, that may be one of those things, because of the rarity of the guitar, that you might want Ovation to do.
Bluebird
Posted 2002-06-13 5:30 AM (#221198 - in reply to #221195)
I would, but the risks of shiping outweigh the risks of a local repair job. Plus the cross-border hassles, duty, etc.
Wayne
Posted 2002-06-13 8:29 AM (#221199 - in reply to #221195)
The bowls back then were painted with a black coat and clear Polyester top coat.
To patch the hole use a fiberglass patch, go to a boat place and ask there.
Posted 2002-06-13 9:42 AM (#221200 - in reply to #221195)
I assume the hole you are talking about is a screw-hole size. If it were me, I would not try to patch it - you'll never get it to match. At any HW store you can buy small nylon screw caps which would cover the hole from the outside. I would affix it from the inside using a dab of superglue. Other options:
1. use one of the small rubber plugs from the elite soundhole rubber dampener things (what ever they're called).
2. just slap an Ovation flower sticker over it
3. use the hole as a cigarette holder
Posted 2002-06-13 12:16 PM (#221201 - in reply to #221195)
I did a similar repair by supergluing a piece of plastic inside the bowl & filling with modeller's putty, which can be bought from hobby shops. I sanded the hardened putty flat & painted it with matt black enamel paint. You have to look real hard to see it.
Paul
Bluebird
Posted 2002-06-13 2:59 PM (#221202 - in reply to #221195)
Thanks for all the tips, guys...except for using the hole as a cigarette holder...guitars are addictive enough without adding tobbaco products!
Besides, what would the difference in density between the fiberglass and the cigarette filter do to the sound??
Wayne
Posted 2002-06-13 3:08 PM (#221203 - in reply to #221195)
It would add a whole new dimension.
