Dual plugs
Wuzhizzoner
Posted 2002-07-16 4:45 PM (#220223)
Subject: Dual plugs
My Ovation 2000 Collector's (sweet guitar) has dual outputs: one is XLR, the other is 1/4-inch. Can these both be plugged in and used at the same time?
Posted 2002-07-16 7:08 PM (#220224 - in reply to #220223)
Subject: Re: Dual plugs
interesting question but to use the xlr you need a dummy plug in the 1/4" so my guess would be no. I have never tried this nor have I had the reason to even try it
Posted 2002-07-17 4:12 AM (#220225 - in reply to #220223)
There could be occasions where both plugs could be used at the same time, such as a split feed to a sound system & recording system, or a feed to the board & a feed to a personal monitor system, but there are better ways to do both of these tasks. A "dummy-plug" is only required if you want to use the XLR output into a jack input as phantom power cannot be supplied to the preamp in this way.
Paul
