Multi hole vs single hole sound
jbx2
Posted 2002-12-21 10:44 PM (#215055)
Subject: Multi hole vs single hole sound
I was at my local Ovation store today playing just about everything in the store. I have an 1868 and noticed quite a different sound from an 1867. I never gave it much thought, but the 1867 had what appeared to me to be a fuller sound. Is this typical?
Jim
MSB
Posted 2002-12-22 3:03 AM (#215056 - in reply to #215055)
Subject: Re: Multi hole vs single hole sound
That’s a really good question and I suspect you get some really good opinions posted about this but I’ll stick my neck out first. The 1867 and 1868 are the perfect match to make your comparison. I am guessing you playing unplugged. If that’s the case, the short answer is yes but you need to do some more homework. Let someone else play unplugged while your listen about 15 feet away. Then do the same thing plugged in. Lastly, play them both through a set of headphones and tweak the preamp on each until you get sound you wont. Then switch between both with out changing the preamp settings. Then come back and tell us what you think.
Mike
Posted 2002-12-22 7:15 AM (#215057 - in reply to #215055)
Yes I think they sound different and yes I think you need to have both of them. Go buy the matching set and put it under your xmas tree. Dave
