The Ovation Fan Club | ||
Random quote: “Music is a moral law. It gives soul to the universe, wings to the mind, flight to the imagination, and charm and gaiety to life and to everything.” -Plato |
How is the neck attached ?
Forums Archive -> The Vault: 2008 | Message format |
IanS |
Joined: June 2006 Posts: 106 Location: UK | I have an Ovation Celebrity CP247 How is the neck attached ? I mean is it glued or bolted or what ? Can it be removed and re-attached ? | ||
IanS |
Joined: June 2006 Posts: 106 Location: UK | The reason I ask is because I've recently started playing in some low open tunings (Leo Kottke etc) and when I get the bass droaning I get an annoying buz in the body of the guitar which I thought was a loose brace. I've now tracked the buz down to where the top of the guitar is vibrating against the fingerboard. I have a gap there as shown in the pictures below. The wad of BlueTac in the first picture stops the buzz happening (so please don't tell me it's fret buzz) Although the gap looks huge in the image it's really only around 1mm at most and there's no gap at all on the other side of the neck. If I put a little pressure on the top of the guitar while playing the gap opens up a bit and the buzzing stops so I can see that the top isn't actually 'fixed' to the bottom of the fingerboard. Is it supposed to be ? So I was wondering if the neck could be removed and put back on again. On the other hand it's just a 'celebrity' so the cost of having that done by a luthier would exceed the value of the guitar. On the other-other hand, it's a really nice guitar and I'm kind of attached to it. The color, by the way, is 'Vintage Orange Quilt' and I've never seen another one like this. Maybe I should just pour a bit of glue down the gap ? | ||
Mitchrx |
Joined: December 2003 Posts: 1071 Location: Carle Place, NY | Originally posted by Axcontrols: Perhaps try wedging a small piece of thin plastic in there insted.Maybe I should just pour a bit of glue down the gap ? | ||
schroeder |
Joined: November 2004 Posts: 4413 | If the blutack fixes it why worry? You can take it out if you sell it and no damage done. Just a thought. | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | I think they're bolted on, but I don't know if glue is also added. Several of the Elite models have a floating fretboard similar to that, but I hadn't seen one on a Celebrity. It's odd that the soundboard would vibrate so much that it would buzz against the bottom of the fretboard. Maybe there's something loose in there that you stop with the Bluetac. You could remove the strings and back access panel and take off the bolts and see if the neck comes off. We have a few others that may have done that already. Check for posts by Old Man Arthur. | ||
Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | I'm pretty sure the Celebs have a standard glued dovetail-type neck joint. Not easy to remove and reset unless you know exactly what you're doing. Your own suggestion will work. Get some glue in the gap to secure the fingerboard extension and that'll cure the buzzing. | ||
cliff |
Joined: March 2002 Posts: 14842 Location: NJ | or shove a shim in there . . . . | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | I'd defer to Paul. I just had another thought. Is the binding around the neck loose? You could be fixing that with the Bluetac. | ||
an4340 |
Joined: May 2003 Posts: 4389 Location: Capital District, NY, USA Minor Outlying Islands | I wonder what kind of glue would work. Cyto-acrylic thick from stew mac? Which would be permanent. Or a wood glue. Probably MWoody would know. | ||
IanS |
Joined: June 2006 Posts: 106 Location: UK | Thank you all for your comments. All your comments are taken on-board I'll be sure to come back and let you know what I did and how it worked out. | ||
Hillwalker |
Joined: September 2006 Posts: 143 Location: Shotley Bridge, Northern England | One final idea; try a little piece of folded stiff card and push this into the gap. Not as permanent as glue, but might work as a shock absorber (I think the Colonial term is damper but we know that means wet :) . If you're glueing, then I would try Aliphatic Resin; much easier to work with than cyano (Superglue); can be smoothed with wet tissue and can be washed off your fingers with water (before it's set obviously :) ) HW | ||
Old Man Arthur |
Joined: September 2006 Posts: 10777 Location: Keepin' It Weird in Portland, OR | Courtesy of Elliot Meldoy (whatever happened to him?) Here is what the neck-joint of a CS257 Celebrity looks like... The innards of a CP might be similar... And here is the thread... Might be helpful | ||
Jonmark Stone |
Joined: May 2008 Posts: 1553 Location: Indiana | I had a similar problem with an Adamas. In humid climates, the tip of the floating FB would curl down just enough to buzz on the top. I bought a sheet of thin felt from the craft department at Wally World and worked it between the FB and top. Solved the problem nicely. | ||
IanS |
Joined: June 2006 Posts: 106 Location: UK | Again, thanks for all the excellent info. That picture from OldManArthur/ElliotMeldoy is showing that the underside of the fingerboard should be stuck firmly onto the top face of the body all the way round. On mine I think it's just stuck along the treble side. | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | You can see that the original glue was well inside the edge, but those are the pictures I was thinking of. Thanks, Arthur. | ||
IanS |
Joined: June 2006 Posts: 106 Location: UK | Thought I'd come back to let you know that the buzz has gone. On the pictures posted by Old Man Arthur you can see that the 257 is glued. On closer inspection of mine it looks as though there's a thin double sided adhesive shim sandwiched between the front panel and the underside of the fingerboard. I guess they're pressed together during assembly. In my case they weren't pressed hense the gap and the fact that the front panel had a lot of movement in that area. Anyway, I have some wood resin. In the UK it's made by Bostik, comes in a green tub, white stuff which dries clear, hard, strong but not brittle. I worked a ton of that into the gap all round. Made quite a mess but it's not solvent based so doesn't affect the gloss finish and excess wipes off with a damp cloth. Job done. So, once again, thanks to everyone who responded. | ||
Mark in Boise |
Joined: March 2005 Posts: 12750 Location: Boise, Idaho | Thanks for the question and the info. This will help someone else down the road. Don't be a stranger. | ||
