Action height
gary buff
Posted 2003-02-24 10:18 AM (#211894)
Subject: Action height
February 2003
Just picked up a new 1861 Balladeer and the action height sits at 3/32 at both E strings....I'd like to get the treble end down to about 2/32; if I remove one shim from under the saddle will it lower both sides by the same amount?
Also, is it a problem getting to the shims with all the pickup wiring, etc. there?
Thanks.
ovation06057
Posted 2003-02-24 4:10 PM (#211895 - in reply to #211894)
Subject: Re: Action height
October 2002
check with service There use to be tapered shims .Don't know if still used .pick-up assy lifts right out should'nt be a problem.
Argle
Posted 2003-02-24 4:20 PM (#211896 - in reply to #211894)
December 2002
I dropped one shim from my elite special and it was "easy as" The pickup is right at the bottom and totally seperate.
