new Ovation problem(correction)
4fingers
Posted 2003-04-19 7:43 PM (#209865)
Subject: new Ovation problem(correction)
March 2003
HI
I just received my new 1863 Ovation
(nylon string, wide neck) and it is all I wanted, but, the 2nd - B string - "slaps" against the neck during normal playing.
I keep it at concert pitch, and have replaced the strings with D'Addario Pro Arte classical strings, and the same thing happens.
What should I do first ? Fiddle with the neck adjustment (probably not advisable) or put a shim under the removable white plastic bridge?
Or what ?
Putting a strip of paper under the B string would lift it, but there goes the tone, I assume.
Thanks for any help or suggestions
Felix
