OT: "ABY" Signal Splitter....advice needed !!!
Tim in Yucaipa
Posted 2008-10-22 8:31 AM (#15640)
Subject: OT: "ABY" Signal Splitter....advice needed !!!
...so, once again I come to the Sages for counsel:
I want to run the single guitar output to two amps with a different effects box on each line. I need to be able to have both amps on at once and to switch between them as well.
I found this thingy: Big Shot
(yup, money is tight)...
whatchathink? :confused:
Posted 2008-10-22 8:40 AM (#15641 - in reply to #15640)
Subject: Re: OT: "ABY" Signal Splitter....advice needed !!!
I have one of these:
Morley ABY pedal
Not as sophisticated as the Radial, but it'll do the same job for less dough.
Tim in Yucaipa
Posted 2008-10-22 8:46 AM (#15642 - in reply to #15640)
Thanks Paul,
Have you experienced any of the problems mentioned in the reviews?
Posted 2008-10-22 9:10 AM (#15643 - in reply to #15640)
I've had mine for about 11 years for the first 6 years it was used 2 or 3 times a week, since then it's used only occasionally, but is too useful to get rid of. Never had a mechanical problem, and can't detect any signal degradation. I only ever used it to switch 2 guitars to a single input, or as a tuner switch. With any passive device like this you might notice problems when running into 2 amps simultaneously. If so you'd need to go to a transformer-isolated splitter. Looks like the Radial might be worth the extra dough, as it is transformer-isolated.
Tim in Yucaipa
Posted 2008-10-22 9:40 AM (#15644 - in reply to #15640)
I agree... I seem to be leaning in that direction... other comments folks?
Posted 2008-10-22 10:47 AM (#15645 - in reply to #15640)
I like the Radial stuff.
I think you already found the best bang for the bucks. Your search is over.
Tim in Yucaipa
Posted 2008-10-22 11:34 AM (#15646 - in reply to #15640)
...done...
click.
