Strange Inlays in UK II fretboard?
GregDK
Posted 2003-11-01 5:31 PM (#201999)
Subject: Strange Inlays in UK II fretboard?
October 2003
I was looking at all the pics of the UKII's in here. And then I was wondering cause the inlays of mine are more similar to the inlays of a ultra gp (you know the cutted edges perloids block).
is that a matter of the year they were made or is it just a funny accident?
greetings
GregDK
Posted 2003-11-01 5:36 PM (#202000 - in reply to #201999)
Subject: Re: Strange Inlays in UK II fretboard?
Not strange at all, the pattern you are refering to was used on the early issue UK11's and could be described as "bow-tie" inlays. Pretty early in production the UK11 changed to block inlays which had a little "bite" out of each corner. This inlay was originally used on the Preacher Deluxe & later on the GP. I've also seen several UK11's with unbound dot-inlaid Preacher necks
Bluebird
Posted 2003-11-01 7:47 PM (#202001 - in reply to #201999)
But have you ever seen one with active electronics?
Wayne
Active UK2??
Posted 2003-11-01 10:54 PM (#202002 - in reply to #201999)
I sent an email to get info on this. A asked about the on/off switches too.
Bluebird
Posted 2003-11-07 5:53 PM (#202003 - in reply to #201999)
My brother was the high bidder on this guitar so I will get the skinny on the active electronics when he gets it.
Wayne
Posted 2003-11-07 7:32 PM (#202004 - in reply to #201999)
That looks like just a normal UK2 to me, not that I'm an expert on that model or anything like that. Batteries? We don't need no stinkin batteries!!!!
Bluebird
Posted 2003-11-07 7:51 PM (#202005 - in reply to #201999)
It looks straight up to me to but the ad specifically mentions TWO steenkin' batteries so it will be interesting to see.
Wayne
Posted 2003-11-07 9:40 PM (#202006 - in reply to #201999)
I'm super curious too. It "looks" too stock, and if it is "active" it's probably not Ovation electronics in there, unless there was a whole lot of modification going on. I'm mainly curiuos as I have thought about experimenting with a pre-amp and those UKII pickups.
Bluebird
Posted 2003-11-13 8:14 AM (#202007 - in reply to #201999)
As suspected, the "active" uk2 turned out to be a standard passive system.
My brother purchased this guitar and would like to replace the Grovers with stock Ovation/Shaller tuners. Does any one have a set to sell? He also needs a truss rod cover, as the tip is broken on this one. This has to be from an electric solid because they are longer.
Thanks!
Wayne
