my celebrity started to buzz what do i do
ole and sara
Posted 2004-03-08 10:46 PM (#192755)
Subject: my celebrity started to buzz what do i do
i have a celebrity cc63 electric/accoustic
it started to buzz when i play hard it sounds like it is the mic, what do i do. do i need new electronics.
Posted 2004-03-09 7:36 AM (#192756 - in reply to #192755)
Subject: Re: my celebrity started to buzz what do i do
I apologize in advance...
Check for bees in the bowl.
Posted 2004-03-09 7:39 AM (#192757 - in reply to #192755)
first start with a fresh battery
second try to determine if the buzz is coming from the electronics or some sympathetic vibrations on the guitar. If it is the electronics call the service department or take it back to the store, if it is the guitar then you need to try to determine what is vibrating and tighten it up.
you may have a loose brace.
ole and sara
Posted 2004-03-10 12:28 AM (#192758 - in reply to #192755)
im sorry for not clarifying more the buzz is when it is un plugged. my model does not hold a battery it only has two knobs, volume and tone. the buzz comes from right below the bridge. and nope no bees.
Bailey
Posted 2004-03-10 1:37 AM (#192759 - in reply to #192755)
Is this the nylon stringed guitar mentioned in another post? If so, check the string attachments for something not right.
Posted 2004-03-10 7:23 AM (#192760 - in reply to #192755)
it sounds like a loose brace.
have someone play the guitar and push your fingers on the top where you hear the buzz if it goes away that is your problem
iconocoustica
Posted 2004-03-10 8:02 AM (#192761 - in reply to #192755)
July 2003
I recently located a sympathetic buzz in my guitar to the circuit board at the plug-in jack, which I don't know if your guitar has. The main point is that you need to stick your hand inside the guitar while playing it and clamp down on everything one piece at a time. Hopefully, you can find the source that way. They can be difficult to isolate. Good Luck.
Franklin
ole and sara
Posted 2004-03-10 3:05 PM (#192762 - in reply to #192755)
thank you it was a loose brace and i hot glued it and it sounds perfect again.
CharlieB
Posted 2004-03-10 8:21 PM (#192763 - in reply to #192755)
January 2004
HOT GLUED?
That makes me cringe
Posted 2004-03-10 9:18 PM (#192764 - in reply to #192755)
some times I think tools should come with a license.
Posted 2004-03-11 8:28 AM (#192765 - in reply to #192755)
I've often felt the same way about guitars (and MICROPHONES for that matter . . . especially on "Karaoke Night").
