198? 1528-9 Ultra...
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Routed the binding and purfling channels. | ||
| DarenSavage |
Joined: December 2016 Posts: 128 | That's a great solution for mounting a glue on neck guitar in your vise set up. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | Fun to watch the progress! | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | DarenSavage - 2017-03-18 11:40 AM That's a great solution for mounting a glue on neck guitar in your vise set up. Thanks! It's very secure and it'll work well when it comes time to apply the finish, too. | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | moody, p.i. - 2017-03-18 11:59 AM Fun to watch the progress! Thanks! I've already routed the binding/purfling channels on your guitar. Next up is my 1612 & 1778. Then, it's time to start gluing. | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | So, is the vital additive in your top finish, crabgrass killer?! Your bench device is 'The Motherhood of Invention". Nicely done! | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | seesquare - 2017-03-19 8:33 AM So, is the vital additive in your top finish, crabgrass killer?! Your bench device is 'The Motherhood of Invention". Nicely done! Yep. That's what gives these guitars their 'killer' sound. (Ba-dum-bump...) Thanks. Yes, I'm very pleased with how well it works to isolate the guitars. | ||
| Jonmark Stone |
Joined: May 2008 Posts: 1569 Location: Indiana | Chaser for the Altoids.... You going to use the Eastwood finish on these, Dan? | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | seesquare - 2017-03-19 8:33 AM So, is the vital additive in your top finish, crabgrass killer?! Your bench device is 'The Motherhood of Invention". Nicely done! You use what's available...... | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Jonmark Stone - 2017-03-20 2:45 PM Chaser for the Altoids.... You going to use the Eastwood finish on these, Dan? Heh heh... Yes. I'll use the Minwax rattle can poly-u as a primer/grain sealer and the Eastwood 2K urethane as the finish coats. | ||
| Jonmark Stone |
Joined: May 2008 Posts: 1569 Location: Indiana | Look forward to your results. Have a project pending. You'll be the guinea pig. | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Jonmark Stone - 2017-03-20 7:04 PM Look forward to your results. Have a project pending. You'll be the guinea pig. If you want that 'killer' sound, don't forget to pick up a jar of crabgrass killer... Heh heh... | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Got the abalone purfling glued into place and razor-planed down. I've never done abalone purfling before, so this one took a deep breath and crossed fingers before diving in. To make the job a little easier, I used Zipflex, which is avaiable through Stewmac. This is the same stuff used my several manufacturers, including Ovation. It's pretty pricey, but after doing the job, it's worth every penny, both from a visual and from an ease of use standpoint.
When I've done the BWB purfling and binding, I use two strips of purfling and the binding. Needless to say, applying the glue to three pieces, then holding them in place while applying the strips of masking tape is a task that requires a lot of concentration. This is because the acrylic glue (basically Duco cement) dries pretty quickly, so I can only work about 6" at a time to assure myself that I don't end up with dry glue joints. The Zipflex is basically short strips of abalone inside a flexible plastic/vinyl channel. The normal binding glue doesn't grab onto it. The Zipflex folks recommend using CA to glue the purfling to the body. They also recommend using a sealer in the grooves so the CA doesn't wick into the wood and discolor it. I did some tests on torrefied scrap and found that the CA doesn't permanently discolor the wood. I planned to use BW purfling on both sides of the Zipflex. The Zipflex folks suggest glueing one strip at a time starting with the inner, then gluing the Zipflex to the inner, then gluing the outer. I found that gluing the inner and the Zipflex at the same time worked okay, so that's what I did. Once this was done, I went back and glued the outer BW purfling. The Zipflex is about half the height of the BW purfling, so I used a razor plane to bring the height of the BW purfling down to the thickness of the Zipflex. That's what you're seeing in the photo above. I'll glue the binding on this afternoon after I clean any excess glue out of the binding groove. I got the binding/purfling on Paul's 1117 this morning before doing Daren's 1528. Because of how well the CA used to glue the purfling on this guitar, I'm thinking of using CA to glue the BWB purfling on the 1612 and 1778 instead of the acrylic glue because I can work more slowly and don't have to worry about dealing with three strips at a once. Instead, I can glue the purfling into place, then go back and glue the binding. | ||
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | Awesome Dan! Always going to school with your threads. Thanks for sharing! Can't wait to see the completed guitars! Zipflex...hmmm... | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Thanks, Ken, and YVW. This guitar represents a couple of firsts for me. It's the first cut-away I've done and the first one with abalone purfling. Speaking of which, although Stewmac only offers green abalone, the ZipFlex folks offer a full complement of shellfish ZipFlex. I'm really glad that I decided to go forward with the ZipFlex instead of chickening out and using BWB purfling on this guitar. Now I have the knowledge and experience to add abalone purfling on the wood bowl CL when the time comes, which I fully intend to do. I may even add abalone purfling to the wood-bowl Elite. After going through the process, it's not as scary as I first thought. There are a couple of minor flaws, mainly due to the CA grabbing at an in-opportune time, particularly around the cut-away, but now I know not to try to glue too much at a time. | ||
| DarenSavage |
Joined: December 2016 Posts: 128 | Looks really cool, Dan. I'm glad you went ahead with the abalone purfling, too. | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | DarenSavage - 2017-03-26 5:26 AM Looks really cool, Dan. I'm glad you went ahead with the abalone purfling, too. I think so, too. Yep. When it's done it should be a pretty blingy guitar. :D | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | I got the binding/purfling scraped down. I've decided that trying to get four guitars done at once is a little too much work. So, I'm going to concentrate on getting this guitar and Paul's 1117 done, then go back and finish the 1612 and 1778. | ||
| jay |
Joined: January 2009 Posts: 1249 Location: Texas | That is a beautiful top. I think this one is going to be a looker. | ||
| 2wheeldrummer |
Joined: February 2014 Posts: 715 Location: moline,illinois | She's definitely a pretty one!!!! Are you going to make your brother a custom label "Ultra Custom Legend DSX" maybe | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | jay - 2017-03-29 11:40 AM That is a beautiful top. I think this one is going to be a looker. Yeah, I think so, too. It's going to get gold tuners and gold EVO frets. Definitely will be one of the nicest Ultras around. | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | 2wheeldrummer - 2017-03-29 4:22 PM She's definitely a pretty one!!!! Are you going to make your brother a custom label "Ultra Custom Legend DSX" maybe Not unless he wants one. We've been calling it a Custom Ultra. | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | Is that the rosette I gave you? | ||
| DanSavage |
Joined: June 2012 Posts: 2347 Location: Pueblo West, CO | Yes. | ||
| DetlefMichel |
Joined: May 2011 Posts: 760 Location: Muenster/Germany | And again I feel like I have 10 left thumbs on my hands | ||
| Jump to page : < 1 2 3 4 5 6 7 8 > Now viewing page 4 [25 messages per page] |
