PICS: Paul Templeman Custom Tuner Buttons
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | That's strange. I've done that on a few of mine and the mini screws worked fine. | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | This is on the 47. I didn't think I'd need different screws either but, with the bushing and the washer in place, I can't get the original screws to work. No one else has run into this? Hmm... | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | My Custom Folklore has the same mimi machines as my 47. I changed from the stock Schaller black plastic "ebony" buttons to full size Pearloid and then I decided I prefered the minis and changed to mini ivoroid. I'm going to check my 47 right now and see if it will take a full size set | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Issue resolved ... after reading Paul's post I went back and tried another machine... I discovered that the worm on the first machine was ever-so-slightly "hung-up" inside the housing, preventing the screw from seating. Disregard my previous post.... | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Jeff, it worked just fine. Checked the 47 and my 1773LX, both took full size buttons using the existing mini screws. When you take off the button make sure the worm stays flush with the body of the tuner. When you slacken off the screw it has a tendency to work it's way out of the tuner body slightly, especially if there's still a little tension on the string. If you don't push it back flush that might be causing the problem. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Just received new stock this morning. Plenty of everything except F/S Rosewood is out of stock. So currently available stock is Walnut - Full size & mini Grained Ivoroid - Full size & mini Tortoiseshell - Full size & mini Rosewood - Mini only Custom buttons | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | Hmmmmmm, not sure how I missed this entire thread but I would be interested in a set of the carved ones when available. | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Carved may or may not happen, but I know that if they do they'll be at least $200 per set. | ||
| Patch |
Joined: May 2006 Posts: 4241 Location: Steeler Nation, Hudson Valley Contingent | Just bought a set of full-size walnuts. They should look quite good next to the burled walnut headstock on my 87C. | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Originally posted by Paul Templeman: In which event, an updated roll call should be in the offing.Carved may or may not happen, but I know that if they do they'll be at least $200 per set. | ||
| Tim in Tidewater |
Joined: December 2005 Posts: 1234 Location: Tidal Mudflats of Virginia | Here! - one carved set - $200 | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Say, Tim, how about a carved set for your doubleneck? That's 18 buttons to you, my friend. Ante up! | ||
| Tim in Tidewater |
Joined: December 2005 Posts: 1234 Location: Tidal Mudflats of Virginia | That would look awesome...ok, 18 in Ebony, 6 in Walnut :D | ||
| Charlie Ramon |
Joined: August 2004 Posts: 709 Location: Germany | Carved set - I'm in! Karl | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | carved set...I'm still in. | ||
| Koenig Kurt |
Joined: April 2006 Posts: 848 Location: Munich, Germany | Still two sets for me as well. Kurt | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | Update: Rosewood full size now discontinued, a few sets of rosewood mini still available. on the next run the rosewoods will be replaced with........KOA!!!!! | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | :cool: | ||
| AussieJames |
Joined: June 2007 Posts: 3084 Location: Brisbane Australia | Walnut for the JR Deacon just arrived today Thanks Paul AJ | ||
| ProfessorBB |
Joined: January 2006 Posts: 5881 Location: Colorado Rocky Mountains | Koa? Someone say Koa? | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | Originally posted by Paul Templeman: :(Update: Rosewood full size now discontinued, a few sets of rosewood mini still available. on the next run the rosewoods will be replaced with........KOA!!!!! | ||
| kotadawg |
Joined: November 2007 Posts: 1486 Location: Cincinnati | Received the walnut for the 1581 and they look great. now if I can just get my friend to return the 1581. Koa would be awesome for my Tacoma. | ||
| Damon67 |
Joined: December 2006 Posts: 6996 Location: Jet City | I wonder what would look best next to rosewood now. One thing I know, it's not Koa | ||
| cliff |
Joined: March 2002 Posts: 14842 Location: NJ | What're they going on?? | ||
| Paul Templeman |
Joined: February 2002 Posts: 5750 Location: Scotland | If you need rosewood I can have some made. They were the slowest sellers, so I didn't reorder this time. | ||
| Jump to page : 1 2 3 4 5 Now viewing page 4 [25 messages per page] |
