Jump to page : 1234
does the pinless bridge suck the snap from strings?
TWA
Posted 2006-03-10 8:48 AM (#272525 - in reply to #272475)
Subject: Re: does the pinless bridge suck the snap from strings?
Get a twelve string. You have two octaves of bass...double the crispness. Or use a coffee stirrer to slide the strings in.
dmkozak
Posted 2006-03-10 10:01 AM (#272526 - in reply to #272475)
Since this topic has risen again, I have a question. If microscopic wood chips fall into the grooves between the windings on the wound strings, wouldn't guitars makers using pinless bridges have noticed this a long time ago? Assuming Ovation is the most prevalent of these makers, wouldn't someone have noticed this 35 to 40 years ago? I can't imagine this hasn't come up in the past, if it is prevalent and so obvious. Therefore, if this is such a problem, wouldn't Ovation and the other pinless bridge guitar makers apply some sort of finish to the inside of the bridge string holes to prevent the microscopic wood particles from lodging themselves into the string winding grooves?
Posted 2006-03-10 10:15 AM (#272527 - in reply to #272475)
I see someone else was really bored and ran out of goofy topics.
Posted 2006-03-10 10:17 AM (#272528 - in reply to #272475)
dmkozak has a valid point.
The difference must be minimal and easily covered by a handful of other subtle design differences and random acts of production. I personaly prefer pinless because it has a neater appearance, such as perfectly aligned and color coded D'addario's.
But with the Pins you have more opportunity to customize and accessorize with fossilized Walrus Tusk and abalone!
Posted 2006-03-10 10:29 AM (#272529 - in reply to #272475)
ahhhhhhh
ahhhhhhhh
Posted 2006-03-10 10:31 AM (#272530 - in reply to #272475)
Woodfiber in the string winding is bullshit... at least when it comes to effecting tone (and assuming you take some care not to pull the string through like your starting a mower). The second you put your fingers on the string you deposit skin cells, dirt and oils and wear from frets and picks is what kills string tone...
Posted 2006-03-10 10:32 AM (#272531 - in reply to #272475)
Open the pod bay door, Hal...
Posted 2006-03-10 10:38 AM (#272532 - in reply to #272475)
"will I dream"
Posted 2006-03-10 11:27 AM (#272533 - in reply to #272475)
...yes
Posted 2006-03-10 11:44 AM (#272534 - in reply to #272475)
I'll most likely kill you in the morning.
Earthbound Misfit
Posted 2006-03-10 12:21 PM (#272535 - in reply to #272475)
The solution is sooooo simple. Just sand the interior of the string holes, starting with medium-fine grit and working down to very fine sandpaper, then apply a thin layer of carbon nanotube coating... works like a charm!
Posted 2006-03-10 12:22 PM (#272536 - in reply to #272475)
"Hello, my name is Inigo Montoya; you killed my father; prepare to die."
Posted 2006-03-10 12:43 PM (#272537 - in reply to #272475)
inconnnncieeeeevable
Highway61
Posted 2006-03-10 12:54 PM (#272538 - in reply to #272475)
It's unbelievable, it's strange but true,
It's inconnnncieeeeevable it could happen to you.
Posted 2006-03-10 12:55 PM (#272539 - in reply to #272475)
You keep using that word. I do not think it means what you think it means.
TWA
Posted 2006-03-10 12:57 PM (#272540 - in reply to #272475)
...to the pain!
Posted 2006-03-10 12:57 PM (#272541 - in reply to #272475)
I am the Brute Squad.
Posted 2006-03-10 1:00 PM (#272542 - in reply to #272475)
You seem a decent fellow. I hate to kill you.
TWA
Posted 2006-03-10 1:00 PM (#272543 - in reply to #272475)
You seem a decent fellow...I hate do die.
Posted 2006-03-10 1:07 PM (#272544 - in reply to #272475)
Get used to disappointment.
TWA
Posted 2006-03-10 1:10 PM (#272545 - in reply to #272475)
Sleep well...and dream of very large women.
Highway61
Posted 2006-03-10 1:10 PM (#272546 - in reply to #272475)
I guess I don't understand.
Won't be the first time.
Posted 2006-03-10 1:15 PM (#272547 - in reply to #272475)
"The point, Oblio, is that everything must have a point."
Posted 2006-03-10 1:17 PM (#272548 - in reply to #272475)
He's just mostly dead.
Posted 2006-03-10 1:23 PM (#272549 - in reply to #272475)
You've been mostly dead all day.
Jump to page : 1 2 3 4
