A subtle & subdued announcement
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | I was just stringing the 1537 for it's journey to StellarJim, and though not a slothead, I put and extra wrap or two around the post to force the strings (esp bass) way down the post to increase the break over the nut. | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | Originally posted by Jeff W.: YUP, that's the way to do it. These guys that say the guitar stays in tune better with only a single wind around the post are FOS. The farther down the post you go (shut up Cliff) the better it sounds.I put and extra wrap or two around the post to force the strings (esp bass) way down the post to increase the break over the nut. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | The two theories are mutually exclusive, my friend. They can both be true, without the other being untrue. | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | You're giving me a headache ... My simple mind (shut up Cliff) tells me that there is like 27 or so inches of string under tension and TENSION (plus diameter, blah, blah,) determines pitch. You can't tell me that an extra 1/2 inch of wrap around a solid post is going to cause the string to change tension by slipping. If the string is slipping on the post, then you did something wrong. I would argue that the theories can NOT both be true because you can not string with only 1 wrap around the post AND wind way down the pole at the same time. Or maybe I'm just too tone deaf to know tat it's out of tune ... Dave | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Shut up, Cliff. | ||
| Waskel |
Joined: February 2005 Posts: 11840 Location: closely held secret | Less trips around the post means less potential delayed stretching of the strings, so the string becomes stable over all it's length faster, and maintains the tension. Having the string lower on the post creates a greater break angle over the nut (shut UP! Cliff) which holds the string tighter in the slot. Whether or not this has a discernable effect on the tone (as it does at the saddle) is arguable. But just as this sharper angle keeps the string from sliding sideways in the slot, it also helps keep it from sliding lengthwise, which isn't really an issue on slotheads (one of the nice things about the design) but can be on pegheads, as there is always some flexing in the posts, since they're only supported at one end. So winding lower on the post could help keep the string in tune. Except that you have to add more windings to accomplish it. Which potentially makes it harder to keep in tune. How's your headache? Oh, the reason I said they were mutually exclusive was because us GWAFOS said less windings meant less tuning, and you OGWAFOS said winding lower on the post made it sound better. Different goals. | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | This GWINFOS (me!) needs a freakin' Tylenol. For gods sake, you just slip the string through the string tube, pull it through the bridge, remove the tube, wrap the string a few times around the post, into the hole, turn the tunner button a few revolutions and start strumming away ... | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | I thought that when the strings went dead, you just bought a new guitar that someone else had already strung. At least that's what that Standing Ovation did and he was my idol. | ||
| mtnbikerfred |
Joined: March 2005 Posts: 1421 Location: Orange County, California | I thought you left the string tubes on.... :D | ||
| worshipleader |
Joined: June 2004 Posts: 580 Location: NW NJ | Fred: If you leave the string tubes in after you string the guitar be sure to get some of StandingO's special String Tube Conditioner (STC in the trade). If you don't, the constant vibration will cause the tubes to deteriorate over a period of a few weeks and congeal into an impenetrable gob of stuff welding the string into the bridge rendering it unremovable. If that happens, you'll have to pry the bridge off and replace it, or just drill some holes vertically through the bridge and top, slap some bridge pins in and forget the pinless bridge idea altogether. As usual, at least before he split, StandingO thought of everything! | ||
| fillhixx |
Joined: November 2005 Posts: 4833 Location: Campbell River, British Columbia | Originally posted by Tupperware: Well, that's how you tune an Double bass, I'm not so sure it works for fretted instuments.turn the tunner button a few revolutions and start strumming away ... | ||
| BrianT |
Joined: January 2004 Posts: 338 Location: SE Michigan | Bring it to my house Brad, I'll re-string it and even tune it up for no extra charge. | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | To late...It's done. I'll be over at 6:30 tommorrow. | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | Originally posted by Tupperware: Originally posted by stephent28: 30 Minutes ??? Hey Stephen how about a little bet. You still got two '97 Parlors? Let's get them both out side by side and I'll race you restringing them. Winner keeps both guitars. Are you up for it? 30 minutes....I have never found it that difficult on a 6 string.....but on a 12 string....ooohhh boy! Dave Originally posted by Tupperware: You're giving me a headache ... My simple mind (shut up Cliff) tells me that there is like 27 or so inches of string under tension and TENSION (plus diameter, blah, blah,) determines pitch. You can't tell me that an extra 1/2 inch of wrap around a solid post is going to cause the string to change tension by slipping. If the string is slipping on the post, then you did something wrong. I would argue that the theories can NOT both be true because you can not string with only 1 wrap around the post AND wind way down the pole at the same time. Or maybe I'm just too tone deaf to know tat it's out of tune ... Dave Originally posted by Tupperware: This GWINFOS (me!) needs a freakin' Tylenol. For gods sake, you just slip the string through the string tube, pull it through the bridge, remove the tube, wrap the string a few times around the post, into the hole, turn the tunner button a few revolutions and start strumming away ... Originally posted by Tupperware: You're giving me a headache ... My simple mind (shut up Cliff) tells me that there is like 27 or so inches of string under tension and TENSION (plus diameter, blah, blah,) determines pitch. You can't tell me that an extra 1/2 inch of wrap around a solid post is going to cause the string to change tension by slipping. If the string is slipping on the post, then you did something wrong. I would argue that the theories can NOT both be true because you can not string with only 1 wrap around the post AND wind way down the pole at the same time. Or maybe I'm just too tone deaf to know tat it's out of tune ... Dave Originally posted by Tupperware: Originally posted by Jeff W.: YUP, that's the way to do it. These guys that say the guitar stays in tune better with only a single wind around the post are FOS. The farther down the post you go (shut up Cliff) the better it sounds. I put and extra wrap or two around the post to force the strings (esp bass) way down the post to increase the break over the nut. Originally posted by Tupperware: You're giving me a headache ... Originally posted by Tupperware: You're giving me a headache ... Originally posted by Tupperware: You're giving me a headache ... Originally posted by Tupperware: :cool: MARKETING GUYS.....THEY START TO SOUND LIKE A BROKEN RECORD AFTER A WHILEYou're giving me a headache ... | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | UTE review... First let me say that the seller (Dave) was great. Good communication and the packaging was first rate. The guitar is as described and came well documented. I'm not very proud of my first slothead re-string job. I tried to take Fred's advise but it still looks kinda sloppy. The hard part for me was keeping the D & G string away from the inside edge of the slot. I better get the hang of it quick so I don't make a little string groove in the slothead. I restrung my AD-II (in 20 minutes) so I could A/B with the restrung UTE (which took an hour and 20 minutes). The UTE is definatly louder, has more sustain, and rumbles with more bass. I thought the AD-II had a good supply of low end but the UTE goes lower. Finger tip picking has more volume. The wider neck is not a issue. In fact it makes finger picking easier. Playing the short neck is noticable. So far I have only found one song where I almost run out of real estate up the neck. I was looking for contrast from the AD-II and Balladeer. I think I have found it. The ute has that Adamas, piano like ring and is a very different flavor than the wood tops. The UTE sitting next to my black, Adamas-like ukelele is quite a picture. The true test will come this evening when Brian & I get together for a jam. Any requests???... Sorry...we don't know "Sweet Home Alabama". | ||
| Tupperware |
Joined: January 2005 Posts: 4903 Location: Phoenix AZ | Originally posted by Slipkid: You mean a black version of THIS ??? The UTE sitting next to my black, Adamas-like ukelele is quite a picture. That's Jerome's 47RI and Uke. Yes, our dear Webmaster has crossed over to the Dark Side. How long before the rest of the EU falls in line ... Brad, congratulations and again on the U681. I'm really glad you like it and not at ALL surprised! Now you need the 12-string version. Dave | ||
| Slipkid |
Joined: September 2003 Posts: 9301 Location: south east Michigan | Yep...that's the look! | ||
| mtnbikerfred |
Joined: March 2005 Posts: 1421 Location: Orange County, California | Originally posted by Slipkid: OK, New guidline. You should'nt be allowed to own more guitars than you can re-string in an hour. I 'm not saying Brad is "slow", but rather some people already have too many slot heads and 12 strings. :D...I restrung my AD-II (in 20 minutes) :eek: so I could A/B with the restrung UTE (which took an hour and 20 minutes) :eek: :eek: | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | Originally posted by mtnbikerfred: so speaks SLOT HEAD FRED.some people already have too many slot heads and 12 strings. :D | ||
| Mark in Boise |
Joined: March 2005 Posts: 12762 Location: Boise, Idaho | Try restringing a hardbody with a Kahler tremelo and locking nut. I gave up after breaking a new string. | ||
| Old Applause Owner |
Joined: July 2003 Posts: 1922 Location: Canton (Detroit), MI | SHHEEEEEEEESSSSSHHHHHH.....give Brad a break! An hour and 20 minutes for a six-string slothead sounds "in-the-ballpark" to me......takes me FOUR FREAKIN' HOURS for my old GC 12-string..... Roger | ||
| mtnbikerfred |
Joined: March 2005 Posts: 1421 Location: Orange County, California | Could be much worse than the stupid Floyd Rose on my Ibanez. At least it's one of the "Kahler Style" with the tube you put the string through instead of having to clamp the string in each saddle... And yes, I can change strings on my slotheads faster than most people can on top posts... :D | ||
| Jeff W. |
Joined: November 2003 Posts: 11039 Location: Earth·SolarSystem·LocalInterstellarCloud·Local Bub | Originally posted by mtnbikerfred: Anyone else, thinkin' "O.K.Corral?"And yes, I can change strings on my slotheads faster than most people can on top posts... :D | ||
| stephent28 |
Joined: April 2004 Posts: 13303 Location: Latitude 39.56819, Longitude -105.080066 | Well the recent times posted have me thinking..... Tuppy, were you thinking my 30 minutes was fast or slow? | ||
| BrianT |
Joined: January 2004 Posts: 338 Location: SE Michigan | Brad was just over with his new U681T. It's quite a horse, got a ton of thud and rumble. And it looks to be in pretty well pristine condition. Nice guitar Brad. | ||
| Jump to page : 1 2 3 4 Now viewing page 3 [25 messages per page] |
