Jump to page : 123
Does anyone actually leave the shims in?
Posted 2005-02-25 9:21 AM (#162354 - in reply to #162329)
Subject: Re: Does anyone actually leave the shims in?
Tone is influenced by the angle break over the saddle. You want a good break angle instead of the saddle being so low that there's only a small angle.
The other factors involved with tone from a higher saddle is that you can play the guitar harder and use heavier strings, both of which contribute to tone.
However, there's a trade off with playabiltiy. Most people want a guitar that's easy to play. My 1537, my main 6 string, has action higher than some people would like. To me, it feels like an acoustic, not an electric. I use medium gauge strings, and while I could remove one more shim, I don't. It notes perfectly up the neck. I've tried it with one more shim out and it loses something.
It's a very personal thing with no right or wrong answer. Mike Wong likes the action on his guitars to be higher than mine. Others like lighter strings and lower action.
Whatever floats your boat...
kkyle
Posted 2005-02-25 9:45 AM (#162355 - in reply to #162329)
Moody, thanks. I'm a weenie now, think I'll add the shims back one at a time when I feel I can produce greater, consistent fret pressure.
Piers
Posted 2005-02-25 2:27 PM (#162356 - in reply to #162329)
I have 1778LX and removed all three shims bit by bit. Each removal was an improvement, with no buzz. I may have lost some tone, but it is much easier to play and after two hours, your fingers are not bruised.
Posted 2005-02-25 6:10 PM (#162357 - in reply to #162329)
I'm with Moody on this one.
I have two 1537's both with Mediums strings and factory set-up that sounded remarkbly similar. I pulled a shim out of one and left the other as is. There was a definite loss of tone and also a bit of string buzz. And to my surprise the lowerd action didn't really make a lot of difference to me while fretting.
The shim went back in. And I can crush walnuts between my thumb and forefinger.
Posted 2005-02-25 7:09 PM (#162358 - in reply to #162329)
String height makes a huge difference to the tone and volume of an acoustic guitar - have you ever been close up to a $20000 classical guitar.? You could drive a Hummer between the fret and the strings at number 12.
If you plug in, or if you're not trying to fill a concert hall then the effect is reduced. But 90% of acoustics are played 90% of the time around frets 1 to 3 where a higher action is much less noticeable - result is a loud, sustaining, clear ringing sound. That's why most manufacturers set them up that way. The exceptions are those that are trying to tempt younger electric players who are used to skinny necks and very low actions on cheesecutter strings.
Gary Moore said he couldn't stand PRS guitars - they were just too easy to play.
Malmsteen (classically trained) said that on the 3G tour neither Satriani nor Vai could play his guitar cos the action was too high.
Like Paul said - it is personal preference, but there is a real difference. You pays your money and makes yer choice.
And no - I haven't taken any shims out.
Hal Jordan
Posted 2005-08-02 8:31 AM (#162359 - in reply to #162329)
August 2005
[QB] But 90% of acoustics are played 90% of the time around frets 1 to 3 where a higher action is much less noticeable - result is a loud, sustaining, clear ringing sound.
:rolleyes: :rolleyes:
actually, more pro players balance where they play on the fretboard more evenly, to utilize more of what's there.
i don't think it's fair to generalize the instrument based on how many beginners/novice-level people play.
there is A LOT more to the guitar than strumming open position chords...IMO
John B
Posted 2005-08-02 8:50 AM (#162360 - in reply to #162329)
January 2004
I like the action as low as possible without buzzing. I normally keep the action right about at Ovation's factory specs as described in the manual. That seems comfortable to me. It's a personal thing, but I don't want to play a 3 or 4 hour gig with a guitar that's hard for me to play.
Posted 2005-08-02 8:59 AM (#162361 - in reply to #162329)
I saw my name mentioned somewhere in this thread - I have no idea why. But just because you're full from the roast beef doesn't mean you have to turn down the cheesecake ...
I have seldom if ever had to deviate from the factory setup wrt number of shims. In the few instances this was required I lowered or raised the action using shims until the action was where I liked it. In the case of one guitar this placed the saddle way too low to get decent tone and on another the saddle was so high (6 shims) that it would not keep from falling over. Both of these guitars were 30+ years old and both had to be sent back to the factory for neck resets. Both are now perfect, although I sold one of them. A sharp break angle over the saddle is essential to transfer the vibration of the string into the bridge, which in turn vibrates the soundboard causing waves inside the body (the deeper the body the better) and those waves pump air (and sound) out of the soundhole. This is in addition to the soundwaves made directly by the soundboard vibrating the air between your ear and the board. Want to experiment? Detune a string by a 5th and what happens to the volume? It goes way down due to less pressure on the saddle. Dave
GN-Nick
Posted 2005-08-02 10:26 AM (#162362 - in reply to #162329)
Hmmm...if you lower the break angle you'll lower volume. I guess if you lower break angle you'll also lower the amount of energy transfered into the top which would affect tone.
As long as the saddle fits the contour of your bridge slot you should be good though.
If you want to lower the height of the saddle but still maintain the break angle, you could always file your pin holes, of course that doesn't work with pinless bridges. ;)
Legend-LX-Fan
Posted 2005-08-02 10:41 AM (#162363 - in reply to #162329)
One thing I have noticed on many guitars not just Ovations is the string height at the nut being way to high. I don't kwow why guitar makers do this. What a difference it makes when the nut slots are cut to give nice low action at the nut.
Hal Jordan
Posted 2005-08-02 11:34 AM (#162364 - in reply to #162329)
August 2005
because it's impossible to raise the nut slots if someone want them higher(for slide, os those who enjoy pain:-)) it is not, as you mentioned, a problem to lower the slots.
leftovertion
Posted 2005-08-02 11:52 AM (#162365 - in reply to #162329)
July 2004
Legend-LX-Fan beat me to it - I had to lower the action at the NUT, and while I was at it, I wanted the strings spaced a tad wider than factory specs, so I went with a new nut altogether (black graph tech, which looks very cool on an all black O, BTW!)
I'm always experimenting (with the shims, string gauges, and truss rod adjustment), not quite there yet.
For me, one of the issues was how hard the O seemed to play in the first 3/4 frets (the "money frets"); so I started lowering the action at the nut. THEN I started working with the shims and truss rod. I also suspect part of it for me is the shape of the neck on my L777 Legend; I may get brave someday and remove some of the 'V' to make it more of a 'C' shape...that will also change it's feel to something I'm more at home with...
...and on and on and on...
:cool: :confused: :rolleyes:
GN-Nick
Posted 2005-08-02 12:41 PM (#162366 - in reply to #162329)
Not to overstate the obvious, but you do know that the truss rod is to adjust neck relief, not action. Right?
Certainly once you adjust the action you may need to tweak the relief, but truss rod adjustment should be fairly rare in the grand scheme of guitar "fixes".
I only adjust the truss rod to back it off for a little buzz, tighten it up if the intonation is out in the middle of the neck.
Also it may need a 1/4 turn when you change string gauges due to the change in string tension.
John B
Posted 2005-08-02 12:50 PM (#162367 - in reply to #162329)
January 2004
That's not that obvoius to many people. I took one of my Martins to have the action lowered a bit and the first thing the guy reached for was the truss rod wrench. Needless to say, I didn't let him touch my guitar. I ended up sanding the saddle down just a little and a little more and....ruined it. I picked up a bunch of blanks and practiced until I was able to compensate the saddle and get the height right. Ovations are so much easier to adjust!
Hal Jordan
Posted 2005-08-02 1:00 PM (#162368 - in reply to #162329)
August 2005
glad you took it away from the guitar butcher...
the truss rod is not actually for adjusting the action, even though it does that in effect. too bad he didn't know that :eek:
jyam4
Posted 2005-08-02 5:32 PM (#162369 - in reply to #162329)
April 2002
Let me add to this mess of a thread:
If you're going to play your guitar, it should feel and sound the way YOU like it. Factory setup is inconsistent. My 1778T came absolutely perfect (for me, at least) from the factory. Super low and no buzz. My 6778LX is set up different (from the same factory). There's probably different individuals setting these guitars up to whatever seems best to them. What I did awhile back was, to get an education (from the internet and other sources) in truss rod & saddle adjustment. This way you are assured to get a guitar that's comfortable to play, and sounds good. While there might be a slight tone vs. comfort issue by changing the action, IMHO, you'll play more, and even be more creative, on a guitar that's comfortable to you.
Joe
Posted 2005-08-02 5:43 PM (#162370 - in reply to #162329)
Factory setup is a generic, one size fits all. The reason for the shims is so that each guitar can be adjusted to suit the player.
Old Applause Owner
Posted 2005-08-02 5:48 PM (#162371 - in reply to #162329)
July 2003
Of course each person needs to have his guitar set up to suit himself. I tried taking out shims on three of my guitars and ended up putting them all back in because the sound suffered too much. That nasty break angle over the bridge thing got me.....
The only one of my guitars that I might like to lower the action on would be the 2005-ES....I wonder if the action was set as high as the factory dared for good sound???....because it sure has it(high action AND good sound)!!!!
Roger
richardd
Posted 2005-08-02 6:03 PM (#162372 - in reply to #162329)
Maybe it's different in the US where the factory deals directly with the retailer but it's certainly not the case here.
The other day I had the opportunity to play a bunch of high end O's that had just landed (Adamas 12 fret, 2005 Ltd, a number a number of new LX models and a Al Di Meola) and all the setups were either bad or awful.
I'd also say I've never heard a flock of O's the sounded better acoustically.
....that Di Meola is calling my name, that thing rang like a bell.
Mike O
Posted 2005-08-02 9:26 PM (#162373 - in reply to #162329)
'Why is that Uncle Crusty?', you ask. Well, because that's where the sound comes out. Clearly, if you glued up your soundhole, you would do nothing more than keep the sound all bottled up inside the bowl.
OK Uncle Crusty..... If your theory is correct then that would mean I need to take my power drill and a 1" forstner bit to my guitar in as many places as possible to maximize the sound output...BRILLIANT!...I'm going to go test your theory immediately....I'll let you know how it works.
:D Mike O
Mike O
Posted 2005-08-02 9:39 PM (#162374 - in reply to #162329)
Seriously though, I appreciate the recent comments on this thread as I have been debating whether to lower the action on my new 1984 collector. I was not aware there was an impact to tone so I think I will leave it alone as the tone is great as is. Also curious if shim material plays a factor in tone? I assume all shims are made of mild steel?
Mike O
Posted 2005-08-02 9:47 PM (#162375 - in reply to #162329)
The shims on your guitar are made out of a pressboard, like a circuit board. Next time you change strings, pull out the saddle. Experiment with it.
Mike O
Posted 2005-08-03 8:43 PM (#162376 - in reply to #162329)
Thanks Moody, I've never been brave enough to tear into one yet,Ive been afraid of damaging the wire leads to the pickup. But I did just get the owner's manual from Ernie so at least I've got an idea of what I'm looking at. Maybe I'll experiment on my Celeb first...Interesting material choice, I would have thought they would use something fairly acoustically transparent like metal.
Mike O
Posted 2005-08-03 9:07 PM (#162377 - in reply to #162329)
When you pull out the saddle, first, gently push it up from inside the guitar with the connecting wires. It's pretty easy.
Now, what I've always been a wuss about is adjusting the truss rod in the neck. Never felt comfortable doing that.
jyam4
Posted 2005-08-03 11:33 PM (#162378 - in reply to #162329)
April 2002
Just to add to what moody said, if it's the "Original" old/new pickup (for lack of a better description), you can lift it straight up from both sides and gently move it aside. Take some Scotch/invisible tape and loop it sticky side out. Now take the tape and lift out the shim. I just finished doing this to my 6778LX. I took off the strings and removed both shims (a mistake). When I restrung the guitar, I noticed it was too low. I loosened all the strings, removed them from the posts, and gently lifted one side of the saddle/pickup, and put one shim back. Now it sounds AND feels great. My advice is to take them out one at a time. What should have taken 30 minutes, took a lot longer. This would be the only benefit of bridge pins.
Joe
Jump to page : 1 2 3
