1967 Balladeer Rebuild...
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | Paul, RC Tonewood has some torrefied Adirondack spruce, (See: Torrefied Adirondack Red Spruce) as does Colonial Tonewoods. (See: Torrefied Adirondack Spruce Guitar Tops) Both are pretty pricey, but not as expensive as what I paid through Blues Creek Guitars. Torrefied Adirondack braces might be a little more difficult to come by. Stewmac is the only supplier I've seen that offers torrefied brace wood, but that's Sitka. A lot of places sell Adirondack spruce brace stock, but none that I've seen sell torrefied Adirondack.
| clrules |
Joined: September 2005 Posts: 138 Location: Birmingham, AL | Very intersting. I haven't been on here for quite awhile and then run up on this.Just curious I have a Balladeer #2486 which should be a 68 or so. My guitar has the caving top thing going on but is still very playable and the neck set is still good. If you wouldn't mind, as a future consideration, could you please send me a private message about the approximate cost to do this? | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | If you recall from our last episode, Jay ordered two sets of torrefied Sitka spruce wood from Stewmac. When the order arrived, both sets were very nice looking, but they didn't match each other in grain or coloration. (batch 1)
It's worth noting that both batches of wood have really nice tap tones and I'm going to keep batch 2 and use it on my 1978 1617. I'm going to buy some torrefied Sitka spruce uncut brace stock to duplicate the brace pattern on my 1976 1619 CL. Just for the fun of it, I sprayed batch 1 with naptha to simulate what the wood will look like under the final finish, then compared it to the original top. Now that this is settled, I'm going to get started on jointing the batch 1, then do some experimentation to taper the top just like was done on the original, which is no simple task. | ||
| jay |
Joined: January 2009 Posts: 1249 Location: Texas | For some reason, Dan omitted my other request. When we failed to match three planks on the 2nd try with Stewmac, I asked him to go to see if he could find a blade we could use to recreate the three planks in the original top. It was just a couple hours drive for him. For some reason we lost our connection and I guess his phone was on the blink for several days after that, because it appeared he couldnt hear it ring. Anyway...this remains a project that continues to get better with each post...thanks again Dan!
Edited by jay 2015-06-26 8:36 PM | ||
| arumako |
Joined: October 2012 Posts: 1093 Location: Yokohama, Japan | Geez...DanSavage...another exciting summer on the BFLG! Your resourcefulness and insights are always inspiring! Thanks for sharing! | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | amosmoses - 2015-06-26 6:34 PM For some reason, Dan omitted my other request. When we failed to match three planks on the 2nd try with Stewmac, I asked him to go to see if he could find a blade we could use to recreate the three planks in the original top. LOL! If you notice, those are Sikorsky S-58 helicopters, not Kaman Huskies. Also, not a rotor blade in sight. Edited by DanSavage 2015-06-26 9:31 PM | ||
| marenostrum |
Joined: August 2007 Posts: 1008 Location: Tuscany, Italy | very nice.....kudos to DAN... | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | Thanks, Ricardo. | ||
| Nancy |
Joined: December 2014 Posts: 1713 Location: Frozen Tundra of Minnesota | As per your usual, VERY interesting, educational and inspiring Dr Savage!!! When you let Paul play it, could you perhaps video it, so that we can all hear it with the torrified wood? I had read about that at Stewmac's, and am interested to see if the artificial aging makes the difference they say! It is so interesting to follow along with your Projects!! Thank You so much for sharing!!! | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | Hi Nancy, Thanks for the kind words. I'd be happy to video Paul playing it and post it on FB to share here. Things are going a little slowly right now because of the irons I've got in the fire. I did get a chance to join the top wood. Next task is to rout the rosette slot and sound hole and build the tooling to allow me to taper the thickness of the top wood. Dan | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | The stuff I needed to continue has arrived and work is continuing.
Add beads of glue (Hysol 9462) where the ribs and spars will be. Add the spars, and put a bead of glue on top. Add the ribs and put a bead of glue on top of these, too. Add the first half of the top layer. Add the second layer and tape some visqueen on top of that to keep the glue from sticking to the stone. Lastly, put the stone on top and let the glue dry. I'll pull the fixture out later today. | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | I've got the practice top wood jointed and I'm waiting for the glue to dry. I've been wanting to try Old Brown Glue for a while now, so I decided the practice top wood joint would be a good place to try it. It's hide glue that's had urea added to it to extend the working time. You heat it up in a double-boiler just like regular hide glue to thin it down. So far, I like it. I'll know tomorrow when I pull the top wood out of the go bar deck how strong the glue is. Edited by DanSavage 2015-08-01 8:05 PM | ||
| clrules |
Joined: September 2005 Posts: 138 Location: Birmingham, AL | Dan, you're an inspiration to all of the Bottom Feeders. I had shied away from repairing acoustics but your knowledge and mentoring has been excellent. The realization that Ovations are pretty durable also makes them somewhat easy to repair. Edited by clrules 2015-08-02 2:05 PM | ||
| SOBeach |
Joined: April 2010 Posts: 823 Location: sitting at my computer | amosmoses - .... I asked him to go heeheehee
Anyway...this remains a project that continues to get better with each post +1 Keep on keepin' on Dan! | ||
| moody, p.i. |
Joined: March 2002 Posts: 15686 Location: SoCal | We "trolls" like this thread...... | ||
| clrules |
Joined: September 2005 Posts: 138 Location: Birmingham, AL | immoody - 2015-08-02 3:32 PM We "trolls" like this thread...... Yes, we do | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | Thanks, guys. I'm glad you enjoy me geeking out. I also pulled the practice wood out of the go bar deck. Here it is sitting in the fixture. The Old Brown Glue seems to have worked pretty well.
Edited by DanSavage 2015-08-03 9:38 AM | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Uh, is the tapering going to throw off your rosette channel? It should be slightly thicker/deeper at the neck-end, versus the bridge-end, right? Now, who's being finicky, here? | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Actually, I'm just trying to pay attention. | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | seesquare - 2015-08-03 4:35 PM Uh, is the tapering going to throw off your rosette channel? It should be slightly thicker/deeper at the neck-end, versus the bridge-end, right? Now, who's being finicky, here? Thicker at the neck-end. Per Charlie's original patent (See: Guitar construction US 3474697 A): The soundboard 16 is longitudinally tapered from a maximum thickness at its upper end to a minimum thickness at its lower end, as best shown in FIG. 2. For structural reasons it is desirable that the soundbox be of greatest strength in the region where the neck is joined thereto, and for this reason the soundboard is of greatest thickness in this upper region. The tapered configuration of the soundboard provides ample thickness in the region of the sound opening 18 and the bridge 28 while the decrease in thickness in the region of the lower bout 42 permits maximum excursion in the latter region. For added strength and durability it is desirable that the soundboard be further reinforced. No, it won't throw off the rosette groove (channel) because the groove will be routed in the front of the top before tapering and the taper will be sanded on the back. Measuring the top wood that came off Jay's guitar revealed that it is 1/8" at the top and 3/32" at the bottom. Paul confirmed this with his 1968 Balladeer. Edited by DanSavage 2015-08-03 9:47 PM | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | OK, then. That works. Thanks. | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | I never noticed before, but if you look at the soundboard thickness in FIG. 2, you can see that it's tapered. See: https://patentimages.storage.googleapis.com/pages/US3474697-0.png | ||
| seesquare |
Joined: November 2002 Posts: 3666 Location: Pacific Northwest Inland Empire | Well, I be jiggered; you're right! Thanks! | ||
| DanSavage |
Joined: June 2012 Posts: 2351 Location: Pueblo West, CO | I had a few free hours today, so I decided it was time to route the grooves and cut the sound holes into the practice top and the final torrefied top. And, the torrefied top. Here's the rosette in the torrefied top. And, how it'll look on the guitar. I'll call the woodworking shop first thing Monday morning and make an appointment to sand the tops. Pics to follow. Just for the fun of it, I'll take some pics during the sanding process to share with everyone.
| clrules |
Joined: September 2005 Posts: 138 Location: Birmingham, AL | Beautimus!! Did you use the Old Brown Glue on both tops? Edited by clrules 2015-08-08 7:38 PM | ||
| Jump to page : < 1 2 3 4 5 6 7 8 9 10 11 12 ... > Now viewing page 7 [25 messages per page] |
