No flattop anymore ...
HobbyPicker
Posted 2006-11-25 7:28 AM (#123810)
Subject: No flattop anymore ...
My 1619-4 is a flattop with deep bowl and traditional soundhole. The top however is not completely flat, the area around the bridge is a little lifted and it goes a little down along the top on both sides of the bridge. I believe it's been this way a long time. I had a guy who repairs guitars for a hobby to look at it, and he believed that the top was "collapsing" and that the guitar needs a new top. It plays fine, and the action is low. I keep a humidifier in the soundhole, but as I play it daily and like to see it, the guitar is hanging on the wall in my livingroom. It's cold in the winter here in Norway, so low humididty in the room can be a problem. Do you guys keep your most precious guitars in their cases, or do you as me prefer to have them decorating your rooms and ready to be played at any time?
Posted 2006-11-25 7:38 AM (#123811 - in reply to #123810)
Subject: Re: No flattop anymore ...
I keep my guitars out in the room and keep the room at 40 percent humidity. Dave
pzavislak
Posted 2006-11-25 10:23 AM (#123812 - in reply to #123810)
Can you guys post side-angle photos of your guitars in the 40% humidity range so that we can have an idea of what it means to have a "normal" top bulge? My 1778LX bulges behind the bridge and is a little depressed right in front of it. Is this normal for ovations?
Charlie Ramon
Posted 2006-11-25 10:48 AM (#123813 - in reply to #123810)
August 2004
I try to keep the humidity in my music room at 45-50%. It's a cellar room and winter humidity falls down to 30 percent. Therefore I use a "Honeywell ultrastar" humidifier. In summer humidity rises up to 70 percent, so I use the "Honeywell duracraft" dehumidifier in this period. Without this precautions I assume the wood top guitars to suffer damages. Maybe the Adamas guitars would survíve it.
Taylor recommends to keep their guitars at 47 percent humidity. I don't know if there are any recommendations from Ovation??
Karl
Posted 2006-11-25 12:16 PM (#123814 - in reply to #123810)
A little bulge is normal. I hang mine and try to keep the humidity over 40% using a small humidifier. I wish I would have bought a larger one with a humidistat.
Posted 2006-11-25 2:52 PM (#123815 - in reply to #123810)
What about us poor folks, with laminated spruce tops? (Isn't that a fancy name for plywood?)
Living in the Great Northwest, in an electic-heat studio apt, I'm sure my humidity fluctuates wildly. Can I expect major humidity problems.
Both of my O's get played 3-4 times per week.
I play something daily. They take turns on the Stand Of Honor. Where I reach-over and grab which-ever. (Small Room)
damon
Posted 2006-11-25 4:00 PM (#123816 - in reply to #123810)
July 2006
I also live in the Northwest (Seattle) and you're fine unless it's a really dry, cold day. The classical guitar shop I frequent says the safe zone is 30 - 80%, ideal is 50 - 60%.
I keep the guitars out where I can easily play them and prefer to humidify the whole room rather than put a wet sponge humidifier inside the guitar.
Posted 2006-11-25 4:14 PM (#123817 - in reply to #123810)
"The classical guitar shop I frequent says the safe zone is 30 - 80%, ideal is 50 - 60%." -(Damon)
That's good to know. Alot of days, 90% is no problem. As for the electric-heat, I have a fan blowing over a fry-pan full-o-water. Hope that helps. This is for both the guitars and me. Cuz sometime that heat is really dry.
Jason_S
Posted 2006-11-25 5:55 PM (#123818 - in reply to #123810)
ive got oaisis humidifiers in all of mine that are in the case's. the ones that are hanging ive got in a small room with a small humidifier set to 40%..seems to work well..jason
ignimbyte
Posted 2006-11-25 8:49 PM (#123819 - in reply to #123810)
July 2004
Almost always, I keep my guitars in their respective cases when I'm not playing them. Once I'm finished playing, I wipe the strings, neck and body with a soft, clean cloth before returning it back in the case. I use either Dampits or Planet Waves humidifiers in all of my guitars during the winter season.
FlicKreno aka Solid Top
Posted 2006-11-25 11:11 PM (#123820 - in reply to #123810)
Hmm..the hygrometer and the necks of my guitars tell wether humidity is high or low,when high , necks stretch causing strings to go high in pitch,and viceversa..guitars are usually hangin`on the wall,some on stands, the solid tops bulge slightly,the laminated have not (so far).Having radiators ,with humidifiers (small watertanks attached to them) helps a good deal,otherwise,when U feel good,the instruments probably will do too.. ;)
:cool:
Vic
Posted 2006-11-26 12:21 AM (#123821 - in reply to #123810)
". . Humidity's too high . . . Humidity's too low . . . I keep my guitars in cases w/hydrometers . . ."
Christ! . . .you guys sound like a bunch of Taylor owners!!!
My SlotHead's been hanging on my wall since I moved here, and it hasn't even had the truss rod adj'd since it left the Factory 30 years ago!! . . . .
Posted 2006-11-26 8:45 AM (#123822 - in reply to #123810)
I'm with Cliff.
All of mine sit out on stands year 'round.
Posted 2006-11-26 9:29 AM (#123823 - in reply to #123810)
Same here. Mine hang on the wall all year. My motorcycle gets better care through the winter. (Ok, granted, my life isn't in danger if my guitar breaks down...)
Posted 2006-11-26 2:55 PM (#123824 - in reply to #123810)
TOT (totally off-topic) What kinda bike?
Posted 2006-11-26 3:05 PM (#123825 - in reply to #123810)
I think it's a Honda Goldwing. Back OT sorta, I just send my wife to buy a bigger humidifier with a humidistat. It was down to 36% in the music room this morning. The little humidifier I got last year can't seem to keep up.
Posted 2006-11-26 4:46 PM (#123826 - in reply to #123810)
GL1500 Goldwing, Arthur.
brainslag
Posted 2006-11-27 7:59 AM (#123827 - in reply to #123810)
Back to the original topic, your 1619 top is probably just fine(without me actually looking at it). Mine was like this since new 23 years ago. Look at the page below, where it says ....Ovation tops are arched slightly to resist changes in humidity...It's not supposed to be truly flat. I dont know if the same applies to the newer guitars.
HobbyPicker
Posted 2006-11-27 8:41 AM (#123828 - in reply to #123810)
Thanks to brainslag for the info about the arched Ovation tops. My guitar gets better for every post I send to this forum! It started out being almost a wreck with collapsed top according to my guitar repair man (a hobbyist, not a pro and definately not an Ovation man). Now I've got a well playing vintage axe with good sound (it's improved a lot since I startet playing it again). I reckon it will be too good to be true after a few more posts!
Posted 2006-11-27 9:21 AM (#123829 - in reply to #123810)
Unless you spend all your time posting and not playing, like some people around here.
Posted 2006-11-27 9:25 AM (#123830 - in reply to #123810)
All (quality) acoustic guitars have very slightly "arched" tops.
MarkM
Posted 2007-02-13 10:32 PM (#123831 - in reply to #123810)
September 2005
My 1619-4 is a flattop with deep bowl and traditional soundhole. The top however is not completely flat, the area around the bridge is a little lifted and it goes a little down along the top on both sides of the bridge. I believe it's been this way a long time....
I believe my 1619 is an '82, I got it in '85 and it has always been like you describe. I've been curious to have it looked at, after this thread I'll make sure the luthier is truly Ovation fluent.
Mark
SF Bay Area
Posted 2007-02-13 10:41 PM (#123832 - in reply to #123810)
Originally posted by Slipkid:
I'm with Cliff.
I keep three out, a Nylon, a 6 string and a 12 string.
Tommy M.
Posted 2007-02-13 11:33 PM (#123833 - in reply to #123810)
January 2004
Maybe I'm lucky, but I haven't had problems in many years and many guitars. I also leave them out hanging. During the cold winter days, I keep the guitar room real cool, to avoid the dry heat. Ovations are pretty tough, and hold up well with climate change. A lot of the older models had problems with finish cracks. I think that's due to the type of finish they used to use. You don't see those cracks on the newer models.
Posted 2007-02-13 11:49 PM (#123834 - in reply to #123810)
Ah ,Norwegian winters are extremely dry,but I suppose ,that like most norwegians, Your house is equipped with electric heating panels,if so,hang some flat tanks against the panels ,filled with some of that Gletcher water,and fill up every second/third day to give the water time to evaporate,I use the same kind of system,I feel better ( breath easier) and my instruments thrive too.Gør det gubben ,din gitar vil takke dig ;)
BTW All older guitars go belly up,string tension will twist the bridge forward,causing top between bridge and soundhole to Dip,and Behind Bridge to arch upwards,everybody I know are convinced that it`s one of the reasons old guitars sound better than new ones
Vic :cool:
