Adamas Suspended Ring
stellarjim
Posted 2009-01-06 12:39 PM (#434810)
Subject: Adamas Suspended Ring
Can anyone describe or point me to an illustration of the Adamas Suspended Ring system that attaches the sound board to the body? I've read this term many times but don't have a clue what it is or why it works. Is it still in use today?
Thanks.
Jim
Posted 2009-01-06 12:42 PM (#434811 - in reply to #434810)
Subject: Re: Adamas Suspended Ring
Someone it probably going to have to hunt through the pictures from the Factory tour. I don't think you can see it if it's the part I'm thinking of, unless of course you break the top off your guitar.
Posted 2009-01-06 1:03 PM (#434812 - in reply to #434810)
I've got a pic of it that I will post to this thread.
Posted 2009-01-06 1:19 PM (#434813 - in reply to #434810)
Jérôme
Posted 2009-01-06 1:22 PM (#434814 - in reply to #434810)
Hello,
Maybe THIS PAGE could help??
J :)
Charlie Ramon
Posted 2009-01-06 1:24 PM (#434815 - in reply to #434810)
August 2004
There is another pic on page 4 of the 1997 Ovation catalog.
Karl
Steve
Posted 2009-01-06 1:26 PM (#434816 - in reply to #434810)
July 2002
That's excellent Jerome. The ring also increases the bowl depth. I'd like to get a mid-bowl made with the suspended ring. It would be interesting to hear the tonal differences on a cutaway single-epaulet midbowl model.
Jérôme
Posted 2009-01-06 1:35 PM (#434817 - in reply to #434810)
Karl is right, that picture is much better to understand how the suspended ring is made.
Here's the original copy of that photo.
Sorry for the big size but she deserves à good rez... :)
J :)
Posted 2009-01-06 1:41 PM (#434818 - in reply to #434810)
... and an eloquent but discrete gold trim ring as on the 1680! ;)
Excellent pic.
Gallerinski
Posted 2009-01-06 3:11 PM (#434819 - in reply to #434810)
That photo gives you a good idea of how thin the CF sheets are relative to the birch core.
Posted 2009-01-06 3:24 PM (#434820 - in reply to #434810)
Sure does. Maybe we should stop pretending they aren't wood-topped guitars.
Posted 2009-01-06 3:55 PM (#434821 - in reply to #434810)
Laminated tops. Must be one of those import guitars. :rolleyes:
Sure is.
Posted 2009-01-06 4:21 PM (#434822 - in reply to #434810)
I've always wondered what the advantage of the suspended ring is (I know it makes the bowl a little deeper)?
Posted 2009-01-06 4:49 PM (#434823 - in reply to #434810)
I would assume ease of assembly, negate the need for purfling/binding, and the fibreglass ring is something that both the top AND the bowl could be readily glued-to to create a solid/stable bond . . .
Posted 2009-01-06 5:43 PM (#434824 - in reply to #434810)
Someone may have a better recall, but isn't this the way they put ALL Ovations together. I seem to recall something on the tour along the lines of what Cliff stated, that the ring was the way to give the top a place to set.
Posted 2009-01-06 6:10 PM (#434825 - in reply to #434810)
I am under the understanding that it improves top resonance...seems like it would...
Posted 2009-01-06 6:59 PM (#434826 - in reply to #434810)
The mounting ring is professionally trimmed to a specific ratio with the top thickness and the mojo variables, as this patent clearly explains...
Duh??
Posted 2009-01-06 7:08 PM (#434827 - in reply to #434810)
More info HERE . Be sure to click on the diagrams.
Posted 2009-01-06 7:23 PM (#434828 - in reply to #434810)
Check out the big brain on Johnny! You are the king of search!
Posted 2009-01-06 7:33 PM (#434829 - in reply to #434810)
Hey, give Woody the credit. He had the patent number in his post!
No big brain, just Google... :D
stellarjim
Posted 2009-01-06 7:57 PM (#434830 - in reply to #434810)
Wow. Thanks for the help. I can see now that the Sound Board is mounted to a ring that is not nearly as rigid as the molded body. This will allow it to move and groove as needed. It sort of reminds me how a speaker cone is mounted in in a flexible ring allowing the speaker to move in and out.
Jim
Posted 2009-01-06 9:48 PM (#434831 - in reply to #434810)
Actually - it's all Jerome's fault once again!
TJR
Posted 2009-01-19 10:27 AM (#434832 - in reply to #434810)
July 2002
Jim
Seeing the cross section picture...I guess that pretty much explains why the epaulettes weren't inlaid into the sound board. 1.) they'd have to have been really thin, 2, It would have cut into the carbon fiber skin.
As a kid..I recall seeing some 3/4 x 3/4" mahogany strips of wood that were show and tell pieces to demonstrate the benefit of using carbon fiber in the guitar necks.
On set of samples was just finished mahogany, the other set(better) had a strip of carbon fiber flatstock bonded on opposite sides. It effectively created an "I"-beam that was exremely rigid. Compared to the bend you could get in the solid mahogany piece, it was night and day.
... Talbot
bvince
Posted 2010-01-01 4:08 PM (#434833 - in reply to #434810)
September 2005
Disregard ... wrong thread.
Posted 2010-01-01 4:13 PM (#434834 - in reply to #434810)
That last picture is soooo cool.
