Any playing Tips ?
IanS
Posted 2009-11-06 5:42 AM (#392192)
Subject: Any playing Tips ?
My problem is playing very (very) simple repetitive pieces.
You know when you try to say "She sells sea shells on the sea shore" a couple of times or pat the top of your head and rub your belly at the same time it often doesn't go as planned.
Well, when learning a new piece I don't have a problem but once it's in my fingers and I can play it without thinking then that's when the problem starts.
Here's a very simple passage that usually trips me up. It's the intro from Leo Kottke's 'The Fisherman'. It's played 4 times but by the time I get to the 4th time I've lost the rhythm.
I try slowing it right down but that usually makes it worse - by that time I'm just thinking too much about it - if you see what I mean.
As you can see - it's very simple - So, any tips ? Am I abnormal? or do other people have the same problem with co-ordination but know how to deal with it ?
ozwatto
Posted 2009-11-06 5:55 AM (#392193 - in reply to #392192)
Subject: Re: Any playing Tips ?
January 2007
G'day Ian.........you're not alone. I often have the same problem. Sometimes I reckon it's because I'm thinking too much instead of just getting into the music and the moment.
Posted 2009-11-06 6:22 AM (#392194 - in reply to #392192)
Stop concentrating on pedaling and balancing and just ride the bike.
And try tapping your foot and swaying your body when you play. Let the rhythm come from the inside out.
Posted 2009-11-06 10:48 AM (#392195 - in reply to #392192)
It will come from repetition. I do a lot of songs with similar finger picking styles. Sometimes I'll be playing a song and my fingers just switch to a pattern from a similar song. Last night I got lost when I was on the third verse. I went through the first two fine. Sometimes you really need to concentrate and sometimes you have to stop thinking and let your muscle memory do everything. Usually it's the latter.
Posted 2009-11-06 10:59 AM (#392196 - in reply to #392192)
You don't have to play something exactly like the author wrote it. When you make slight changes to it, you're making it your own.
If you think Kottke's stuff is difficult (and he's a really good player) try learning some Jerry Reed tunes. He was a monster player.
You might keep in mind that most great players never play the same thing exactly the same way twice. Even tho' it's written a certain way by the people transcribing it, Reed would never play the same thing twice. In the 60's, when he was doing studio work, it was said that if a tune required 20 takes, he'd play it 20 different ways.
As Bobbo and MIB said, stop thinking about it and just play it. What comes out will be a Kottke tune with your stamp on it. Practice, practice, and practice some more. Then play the tune, not the tab....
dobro
Posted 2009-11-06 3:10 PM (#392197 - in reply to #392192)
First, use a metronome or drum machine. Always. Second: develop the practice of listening to what's OUTSIDE you (say the band or the metronome) and NOT just your own head-and-fingers complex. Ears up and "out" on metronome, fingers on notes, tap your foot...
Watch THIS LESSON at 2:30 onward
Posted 2009-11-06 3:57 PM (#392198 - in reply to #392192)
What happens to me sometimes is I'll be playing something and then I'll think hey that sounds pretty cool, then follow the cool thing whatever it was, then forget where I was in the song. It's great for jamming, not so good if others are focused. It's like, oh look, a bright shiney musical penny, and then saying geez how'd I get here.
Posted 2009-11-06 4:20 PM (#392199 - in reply to #392192)
I watched that and tapped my foot like a middle age white guy. Not good....
Meuti
Posted 2009-11-06 5:58 PM (#392200 - in reply to #392192)
August 2009
Moody... This is the perfect answer! Thread can be closed now. Thumbs up!
tpa
Posted 2009-11-07 8:14 AM (#392201 - in reply to #392192)
I tried the figure and it works for me using this right hand fingering:
E|________|
H|__A_A_A_|
G|_M-M_M_M|
D|__I___I_|
A|P___P___|
E|________|
For playing repetitive patterns I find that practice does a lot. This first song I seriously worked with was "Every breath you take" by The Police (band). Different pattern different style different technique (flat pick) but getting the thing played with the right musical flow requies practice in either case. Learn the pattern and practice it. Many times. Actually you don't need the guitar to practice right hand fingering because its more about body control than about music.
Losov
Posted 2009-11-07 9:00 AM (#392202 - in reply to #392192)
October 2008
Take it in stages, Ian.
For the moment, play only the alternating bass with your thumb, which is on the beat one-two-three-four. After you can do this and stay in time, try adding the open G in between the beats, one-and-two-and-three-and-four-and, using your index finger to attack the third string. Once you get that comfortable, attack the 2nd string C with your middle finger at the same time you use your thumb for the alternating bass.
Viewed as a whole, it can be intimidating. in parts, it becomes more manageable. Good luck
bvince
Posted 2009-11-07 9:56 AM (#392203 - in reply to #392192)
September 2005
It's interesting to read how many different ways you guys approach the same challenge. There is no wrong approach here, just different roads to the same place (hmmm ... that sounds like it would make a nice song :) , anyway ... back on the trail ... I personally use Losov's approach in taking small bites until I can put it all together through muscle memory. That works best for me, but Ian, you'll need to try out the different ideas and see which technique produces the best results for you.
standing
Posted 2009-11-07 1:05 PM (#392204 - in reply to #392192)
December 2008
E|________|
H|__A_A_A_|
G|_M-M_M_M|
D|__I___I_|
A|P___P___|
E|________|
That's a good tip, if you can figure out how to tune the second string to an "H" ;)
FlicKreno aka Solid Top
Posted 2009-11-07 5:03 PM (#392205 - in reply to #392192)
E|________|
H|__A_A_A_|
G|_M-M_M_M|
D|__I___I_|
A|P___P___|
E|________|
And That`s how it is here in Danmark ..
as I`m NOT a Dane ,I do n`t use that scale , and have forgotten how to explain it , so TPA will have to do that , ... he did n`t make a mistake.
Meuti
Posted 2009-11-07 9:31 PM (#392206 - in reply to #392192)
August 2009
It's the same way in Germany: an H is similar to a B. "Your" B is an H for us. And a "B" in Germany (or Denmark) is a Bb (B flat) in the USA.
It DOES sound confusing, I know :D
standing
Posted 2009-11-07 9:59 PM (#392207 - in reply to #392192)
December 2008
Excerpt from Wikipedia:
In parts of Europe, including Germany, Poland and Russia, the natural symbol transformed into the letter H: in German music notation, H is B♮ (B-natural) and B is B♭ (B-flat).
TPA, FlicKreno, Meuti:
I apologize for my ignorance and attempt at a cheap joke. I really thought it was a typo for a "B." I had to go look it up to be sure you were not joking… I guess that's part of being a member of "The Sarcastics" on the ning site, I assume sarcasm before sincerity…
…but I do sincerely apologize for my stupidity, I never knew that, so thanks for the education!
Posted 2009-11-07 10:35 PM (#392208 - in reply to #392192)
IanS; all you need to know.
Think less, do more.
Practice 3 hours a day for 10 years.
If that doesn't do the trick. Quit.
Posted 2009-11-07 10:42 PM (#392209 - in reply to #392192)
STANDING : ..
I never meant to " Put ye Right "..
It was Only meant as a Re- assurance that what IAN S was talkin` bout was understood .. albeit in a " Danish way " ..
I , fer One , have read many of y`er Exellent posts , and therefore Know that yer allways Sincere , ..and that yer Good company , .. Cheers !!
Vic
standing
Posted 2009-11-08 3:29 AM (#392210 - in reply to #392192)
December 2008
Vic
Now you ARE being sarcastic… ;)
But thanks, I'm glad I learned something new.
I've got it now; if you tell me to play a "B" and I play what I think is a "B", you'll say; "no, it's a half-step down from an "H", I'd have to guess that a half step down from an "H" must be G#, so I'd still play the wrong note. Who's on first? That's right! ;)
dweezil
Posted 2009-11-08 4:47 AM (#392211 - in reply to #392192)
Practise, then more practise. Use a metronome. I find slowing it down and even breaking it down even further, i.e. play the first 4 notes over and over again then the 2nd 4, then put it together.
David Van
Posted 2009-11-08 12:18 PM (#392212 - in reply to #392192)
September 2009
There is a syncopated part in "Last Steam Engine Train" where it is going back and forth between an A chord and an E chord that gives my right hand fits and I am thinking some of these suggestions may help me with that... Off to practice and try them out! Thanks guys!
tpa
Posted 2009-11-08 3:06 PM (#392213 - in reply to #392192)
:p I should have known better ... no offense taken.
IanS
Posted 2009-11-09 7:11 AM (#392214 - in reply to #392192)
Thanks everyone. (although some of you seemed to be answering a different question - thanks for the tips anyway :) )
Mark - Yes, I do that too - one moment I'm doing a hammer on in Classical Gas and suddenly find myself playing Bert Jansch's Angie - LOL all good fun though.
Moody - I can usually figure out my own way to pick through any complex passages - as I said though, it isn't the complex bits I have trouble with (well, I do, but that's a different problem) - I mean they don't come any simpler than that example I posted - it's the short simple passages (I call them 'rolls') that are repeated many times where I find my hands seizing up - somebody called it a 'fit' - yes, I can relate to that.
dobro - Yes, thanks - tapping my foot does appear to help.
Many other replies explained how to play that tab sample I started with - thanks - but that was just a sample - I just posted something really simple as a way to indicate the kind of thing I find problematic - playing things like that one or twice isn't a problem but in some tunes they're repeated over and over as a fast 'roll' and that's where I find my hands go off in the wrong direction and the purpose of my post was to find out how many other people have this problem playing the same few notes over and over as a roll.
dweezil
Posted 2009-11-09 7:34 AM (#392215 - in reply to #392192)
Again the answer is to play it SLOOOOOOOOOOW and get it programmed into the muscle memory.
IanS
Posted 2009-11-09 8:11 AM (#392216 - in reply to #392192)
Thanks dweezil.
I had to go back and read my original post to remind myself what I asked.
As I said - when I'm learning a tune and playing it slow I don't have a problem - even when I start practicing at performance speed I don't have a problem - But - once it's in the muscle memory - when I can play it without thinking - that's when the problem starts.
