Slothead vs. Standard - need opinions
edensharvest
Posted 2006-05-10 12:27 PM (#255408)
Subject: Slothead vs. Standard - need opinions
March 2006
I'm looking to custom order a Custom Legend 12-string. In doing that, I just realized that I could possibly order a slothead.
What are specific pros & cons of slothead versus standard pegs?
(Let the games begin!) :D
Posted 2006-05-10 12:59 PM (#255409 - in reply to #255408)
Subject: Re: Slothead vs. Standard - need opinions
Probably not a huge difference in sound, but a royal pain in the butt changing strings.
Posted 2006-05-10 1:00 PM (#255410 - in reply to #255408)
Slothead: More difficult to change strings,(especially a 12 string).
Slothead: Sharper break angle for strings,(better sound).
Steve
Posted 2006-05-10 2:16 PM (#255411 - in reply to #255408)
July 2002
Aren't the slothead 12's wider at the nut?
GregoryS.
Posted 2006-05-10 2:18 PM (#255412 - in reply to #255408)
April 2005
See, i TOLD you Andrew!
edensharvest
Posted 2006-05-10 2:55 PM (#255413 - in reply to #255408)
March 2006
Yes, you did...though I never mind stirring up conversation and controversy...
GregoryS.
Posted 2006-05-10 3:42 PM (#255414 - in reply to #255408)
April 2005
and a great job you do of it, too!
Posted 2006-05-10 5:16 PM (#255415 - in reply to #255408)
best comparison I can give...the 1658 (slothead) and the 1659 - other than the neck and placement of the bridge, identical Custom Legends (AAA, same brace, deep bowl)
both great voice, more of a "harpsichordic" voice on the slothead. some like it, some don't.
my three slothead 12's are the shiny bowl, GC acoustic, and the 1658.
I like it which is why my slothead 12's get played while the 1659 and the 6759 hang on the wall.
Posted 2006-05-10 6:04 PM (#255416 - in reply to #255408)
Around the first of the year I custom ordered a
12 fret 12 string slothead cutaway .
It is supposd to be finished sometime in May/June.
edensharvest
Posted 2006-05-10 7:11 PM (#255417 - in reply to #255408)
March 2006
So, overall, does the extra tension of the strings' angle over the nut on the slothead:
A. Increase sustain or overall resonance?
B. Wear your strings out faster?
C. Change how well it stays tuned?
D. Make you jump up and down like a chimpanzee?
E. All of the above.
edensharvest
Posted 2006-05-10 7:12 PM (#255418 - in reply to #255408)
March 2006
So, BTW, where's Tuppy?
I thought for sure he'd have SOMETHING to say on this one...
Posted 2006-05-10 7:27 PM (#255419 - in reply to #255408)
The width of the nuts should be the same.
Changing strings on a slot are a pita.
Typically a slothead is 12 frets, flathead is 14.
Yes there is a sharper angle for better sound because of slightly higher tension. You want to believe it, go ahead, it's true. Now put on a blind fold and tell me you really can hear it.
This sharper angle will not wear out your strings faster or make them stay in tune better.
One of these will make you jump like a monkey but I forgot which one.
Posted 2006-05-10 8:15 PM (#255420 - in reply to #255408)
The Other One. :D
45flint
Posted 2006-05-10 9:35 PM (#255421 - in reply to #255408)
March 2003
I know the 12 fret neck makes a difference. But explain to me how the string angle or tension beyond the nut can make any real difference. Wouldn't the part of the string that vibrates between the nut and the bridge be at the same tension no matter what angle the string beyond those points are? Seems to me the reality is that slotheads tend to be on 12 fret necks and that is the plus. I think a slot head just looks cool.
Steve
Posted 2006-05-11 10:11 AM (#255422 - in reply to #255408)
It all makes a difference. The differences may be subtle, but they are there. An acute angle over the saddle or nut results in increased srtring tension, it's basic physics. A slotted headstock has the advantage that it acheives an acute break angle at the nut without the need for a sharply angled headstock, which lessens the chance of a neck break at the nut in the event of an accident.
Posted 2006-05-11 2:37 PM (#255423 - in reply to #255408)
I noticed the other day (only took me 30 years) that my Matrix has a more sharply angled headstock than my other O's. Maybe they designed that in with the urethane neck.
ChatMan
Posted 2006-05-11 7:16 PM (#255424 - in reply to #255408)
August 2004
I read PT's explanation and while his statement regarding the break angle at the nut and normal force between the string and the nut are pretty obviously correct, I never could figure out why it would matter. I've heard theories that try to relate neck vibration to over all sound but the pertinent interface in that regard I would think is the body/neck joint.
About the only mechanism I can envision that might make a difference, due to string/nut realtionships, is the increased normal force creates a lager frictional force between nut and string that in turn prevents any energy due to string vibrations (some component of which will be realized as forces that try to slide the string in the slot) from be lost due to sliding movement in the slots cut into the nut.
That ought to nail the lid on this thread ;)
Posted 2006-05-11 7:32 PM (#255425 - in reply to #255408)
It is a well known scientific fact that slotheads look a googol to the power of 8 cooler than flatheads. Break angles/sustain/string wear don't come into it. Slotheads are just the bee's knees.
Posted 2006-05-11 7:59 PM (#255426 - in reply to #255408)
The "bee's knees"? Jeez, you brits don't know anything. The expression is the "cat's ass". Altho' you don't want to use that expression around Cliff... if there's no llama around, he'll start to get excited.
Posted 2006-05-11 8:12 PM (#255427 - in reply to #255408)
Especially this time of year.
brainslag
Posted 2006-05-19 1:46 PM (#255428 - in reply to #255408)
It would be nice to be able to order a 14 fret neck with the slotted headstock. The bridge would move up a bit and out of the 'sweet spot', but you get the cool headstock, and a more usable neck. Weren't the old 12 strings 12 frets for strenth purposes? As soon as the KAMAN bar came out, they moved to 14 frets, and switched to the flat headstock.
Posted 2006-05-19 2:25 PM (#255429 - in reply to #255408)
Why not just custom order a 12 fret slothead cutaway like I did. Then you have the cool factor, the better sound, and access to the upper frets!
Mitzdawg
Posted 2006-05-19 2:47 PM (#255430 - in reply to #255408)
July 2004
How exactly does one order up a custom? Some other sites I've visited have a "menu" of what the available choices are with a price list so you can talk ourself out of things pretty quickly. Is there a form or procedure or is it just a phone call?
BobbyJ
Posted 2006-05-19 2:47 PM (#255431 - in reply to #255408)
March 2006
StephenT28,
Is that a UTE cutaway?
Posted 2006-05-19 4:08 PM (#255432 - in reply to #255408)
No Bobby,
It is actually a 12 string 12 fret slothead cutaway. I will try to post some pics.
