My fix for the VIP dumb dummy plug problem
TexasDoc
Posted 2006-08-09 7:33 PM (#244768)
Subject: My fix for the VIP dumb dummy plug problem
I finally fixed the poor design on the dummy plug issue that the VIP has. Although I think that just a little more in engineering effort could have made it easy (make the tuner work like the OpPro), they didn't. Here is my fix so I don't have to carry around the dummy plug in my pocket. It is small enough that I can play with it in and leave it in while the guitar is in the case without problems.
1. Went to Radio Shack. Bought the plug shown below. Cut the plastic sleeve as short as possilbe to still hide the contacts.
2. Fill the remainder of the plug with epoxy for a better look.
3. Put scotch tape on half of the shaft.
4. Insert into plug and leave it there permanently.
When I want the tuner to operate, I twist the knob/dummy plug until the tape is away from the circuit board, allowing electrical contact, thus powering the tuner. I can tell when it is where I want it because the tuner powers on. When I want to turn it off, I twist it until the power light on the tuner goes off. This is when the tape is between the contacts and the tuner thinks the plug has been pulled (it is an electrical contact, not a mechanical one).
My next step is to try to grind away half of the shaft of the plug so the tape won't wear down, marked in red in the photo. (I haven't had this problem yet).
I first tried to cover the shaft with epoxy, but it was too thick to insert into the hole. Next I tried masking tape. Nope, still too thick. Finally the scotch tape worked. I was afraid the tape wouldn't last, but it has held up so far.
JeffreyD
Posted 2006-08-09 9:00 PM (#244769 - in reply to #244768)
Subject: Re: My fix for the VIP dumb dummy plug problem
September 2004
Very creative.....might have to give that a shot.
texbaz
Posted 2006-08-09 9:15 PM (#244770 - in reply to #244768)
t,
That is pretty sharp engineering, How about, since you know where the female plug contacts the the shaft of the plug take a die grinder cut a sustantial chuck out then fill it back with an epoxy filler so that the actual on postion is small maybe even drill the beginning of a hole to form a dimple so that when you turn it on you can feel it hit the detent or vice versa. looks good.
TexasDoc
Posted 2006-08-09 9:47 PM (#244771 - in reply to #244768)
Yeah, that's the next plan when I get a round tuit. Since it is working at the moment, its toward the bottom of a very lengthy list.
GregoryS.
Posted 2006-08-09 10:16 PM (#244772 - in reply to #244768)
April 2005
Kewl....I just ordered an Op-Pro Studio, and use that instead of the VIP...or use the Op-Pro out of my 1777LX.
THe VIP is great in studio, but other than that I much prefer the OP-Pro or the Op-Pro Studio.
TexasDoc
Posted 2006-08-09 10:30 PM (#244773 - in reply to #244768)
I didn't think you could switch out the VIP for the studio or OpPro. I think the Studio and pro are switchable, just not the VIP. I think the can is different.
Posted 2006-08-10 8:01 AM (#244774 - in reply to #244768)
I believe BM is right, Greg. According to the Q&A at the Factory, you'll have to switch out the cans.
Posted 2006-08-10 9:34 AM (#244775 - in reply to #244768)
Not that I would need it (I've always felt that on-board tuners were for "girls"), but how taking ttenn's cut-down plug and wiring a little, mini toggle switch onto the end??
Posted 2006-08-10 10:00 AM (#244776 - in reply to #244768)
That's exactly what I was thinking, Cliff.
Something like this?
Posted 2006-08-10 10:12 AM (#244777 - in reply to #244768)
Actually, if you only "plug-in" w/XLR . . .
. . why not just replace the 1/4" jack with the above push-button??
(y'might have to modify your case a bit to keep it from switching on/off as it goes in/out of the case)
Posted 2006-08-10 10:13 AM (#244778 - in reply to #244768)
OOOH-OOOH!!!! . . . I KNOW!!!!
Hook it up to a "Clapper"!!!
(clap on/clap off) . . . .
Posted 2006-08-10 10:35 AM (#244779 - in reply to #244768)
Hmm.. Nice idea. Unless you actually get applause after a song.
Posted 2006-08-10 10:44 AM (#244780 - in reply to #244768)
The idea of replacing the jack is close (until you find yourself in a situation where there is no XLR available), but why not just put another 1/4" hole next to the output jacks and install one of these?
Mounts in a 1/4" hole. Very unobtrusive. Hopefully your jacks are near the endpin?
Seems this would also allow you to use XLR where there is no phantom power available without having to use the dummy plug.
TexasDoc
Posted 2006-08-10 11:56 AM (#244781 - in reply to #244768)
Thought about that too, but didn't want to drill a hole in the bowl if I get rid of the 2K6.
Actually, replacing the 1/4 inch jack is probably the best idea yet, but there are a few problems. Firstly, the 1/4 inch and the XLR jacks are both mounted to the same circuit board. Since the XLR mounts externally to the case with exterior screws, you would have to flip it around 180 degrees to open the 1/4 inch plug hole. You will still have to deal with the 1/4 inch plug, because it sticks out a little.
I guess if you are daring with a soldering iron, you could remove the 1/4 inch plug from the circuit board, then install the above switch. If you want to return it to stock, just re-solder the plug back in place.
Initially, I wanted to find a REALLY small push on/push off SPST switch that I could insert into the 1/4 inch plug, but couldn't find one small enough.
The wiring is pretty easy.
Posted 2006-08-10 12:03 PM (#244782 - in reply to #244768)
I've never had t'mess with any of this stuff w/my lowly guitars and their archaic electronics . . . I guess (sometimes) there are advantages t'being poor . . .
(I usually just go from FET3/OpX to my pedal board which is XLR-out)
Posted 2006-08-10 1:13 PM (#244783 - in reply to #244768)
The first switch I found may not fit 'into' a 1/4" plug, but it wouldn't be that hard to make a modified barrel to attach it to.
bauerhillboy
Posted 2006-08-11 3:22 AM (#244784 - in reply to #244768)
Whose job is it to design these preamps, anyway? I wonder if they're reading this. John <>{
Posted 2006-08-11 10:10 AM (#244785 - in reply to #244768)
It seems to me they had an explanation for this at the Q&A, I just can't remember right now. I'll check the video and see if I caught it.
Posted 2006-08-11 10:39 AM (#244786 - in reply to #244768)
I seem to remember it being about the tuner "timing out" and that with the more "features" being added (compression, mic modeling, etc.), it was decided to shorten tuner time-out to save battery life . . . I don't remember if the dummy-plug thing came up . . .
". . let's go to the video tape . . ." . . .
Posted 2006-08-11 10:45 AM (#244787 - in reply to #244768)
Cliff's correct.
Consider that the schematics have to go out to whoever the builder of the "board" is so there isn't a lot of room for change until the parts are used up and Rev 1 is contracted.
As the owner of a 12 string with an OP Pro all I can say is learn to tune faster!
Posted 2006-08-11 10:47 AM (#244788 - in reply to #244768)
Yeah, I seem to remember a bit of double talk around it about the tuner time out as well... I don't think the question was really answered. Perhaps just a design error that nobody wanted to fess up to.
I'll check the tape later.
TexasDoc
Posted 2006-08-11 11:27 AM (#244789 - in reply to #244768)
From my memory:
They designed it on purpose that way to decrease battery usage. When the preamp/tuner is powered there are "alot more things going on" that draw more power. Therefore, to increase battery life they designed it this way.
My take: It would have been simple to take a power lead from the battery to the tuner button connected to a timer relay. When the tuner button is pushed, the tuner (or tuner and preamp) gets powered. When the timer expires, everything powers off. It doesn't use any more battery that if you power it with a plug. Make it work like the OpPro.
My opinion: TO ME, sounds like a design failure. Somebody didn't realize it was a problem until after the design was approved and production had started.
(I probably don't have all the facts and may be completely wrong. I'm not trying to offend anyone at the factory. I started this thread to show how I worked around a problem I am having. When I posed this question at the factory tour, it seemed TO ME that we got the run-around. Please don't ruin my custom ordered guitar that I'm still waiting for!!)
[EDIT: Paragraph added]
However, it is designed a little differently. The tuner stays on until either the tuner button is pushed again or the plug is removed. There may not be a timer relay designed into this preamp. Without the timer, the only way to kill the circuit is manually with another push of the button or removing the power. Still they could have made the tuner button into a push on/push off switch.
TexasDoc
Posted 2006-08-11 11:39 AM (#244790 - in reply to #244768)
The tuner doesn't time out. It stays active until the tuner switch is pushed again or the plug is removed.
Posted 2006-08-11 12:26 PM (#244791 - in reply to #244768)
Interesting. So if the time out circuit was um... overlooked, the only option may have been to require it be powered off to save the battery when not using the preamp.
Posted 2006-08-11 12:41 PM (#244792 - in reply to #244768)
Need Epaulet Solar Panels to power the preamps off of stage lights. Try that on a Martin!
